NEED HELP: 67 f100 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 07-15-2010, 09:15 PM Thread Starter
67 f100
MY 67 F100 HAS DRUM BRAKES ALL AROUND BUT I'M THINKING OF PUTTING IN DISK IN THE FRONT.MY QUESTION IS FROM WHAT YEAR OF TRUCK CAN I SWAP THE DRUMS FOR THE DISK BRAKES.I'M NOT 100% SURE BUT I GUESSING SOMETHING WILL FIT.
THANKS IN ADVANCE
BIG-PAPA
big-papa is offline
post #2 of 3 (permalink) Old 07-15-2010, 11:09 PM
Check out these guys http://www.tsmmfg.com/ they know thier stuff, and I am sure they have some front and rear conversion kits that you could use
post #3 of 3 (permalink) Old 07-16-2010, 03:30 AM
First question is do you have to change the spindle. If so, you may want to consider leaving it alone. Changing the spindle requires driving out the king pins. Not the easiest thing to do without taking out the I-beams and having a big press handy. Of course, if you take the I-beams out, you would be better off just swapping the whole assembly out. A lot less labour, and it gives you the opportunity to put in new pivot bushings, radius arm bushings and king pin bushings. New brake hoses and probably a bit of brake line plumbing. A new master cylinder is a must. Good time for a power booster if you have "leg-strong" brakes. Also consider an equilizer switch if it doesn't have one already. For the most part, I believe pretty much anything from 1967-1979 should fit the bill.
1967 f100 serial number big-papa F-150 Pre-1997 Forum 5 05-03-2010 11:43 PM
Check out this sick 1951 F100 burtoj2 Truck/SUV Talk 8 08-19-2009 12:32 PM
New F100 out in '09??? f150phule Ranger Forum 34 03-20-2008 06:48 PM
