NEED HELP: Starter issues - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 10-22-2010, 12:06 AM Thread Starter
Starter issues
Just wondering if it is difficult to replace a starter on a 87 F150 4.9l engine. Any info you can give me would be much appreciated!
syl-63 is offline
post #2 of 9 (permalink) Old 10-22-2010, 12:50 AM
not really. Disconnect the battery first. Top bolt will be the most difficult. Top bolt will be a 1/2" or a 13mm socket and bottom if I remember correctly is a 9/16
post #3 of 9 (permalink) Old 10-22-2010, 01:25 PM
Use 6-point sockets!
post #4 of 9 (permalink) Old 10-22-2010, 09:55 PM
Why does it need to be replaced?
post #5 of 9 (permalink) Old 10-22-2010, 11:13 PM
Make sure you've ruled out the fender mounted solenoid first... they're very common to go on those trucks!
FULLSCALE is offline
post #6 of 9 (permalink) Old 10-23-2010, 12:51 AM
mine's never gone in 14yrs but my starter has 2x
post #7 of 9 (permalink) Old 10-23-2010, 03:34 PM
I've never had my solenoid go yet and it's original but a quick tightening of starter bolts and ground strap bolts may solve some issues. My '76 used a solenoid per year. Always kept a spare and enough wrenches to change it. They were cheap to keep a spare. Use to be about $10~$12.
post #8 of 9 (permalink) Old 12-22-2010, 10:16 PM
robbyboy's Avatar
make sure you use anti-seize on the starter bolts
robbyboy is offline
post #9 of 9 (permalink) Old 02-17-2011, 04:05 PM
pikeslayer's Avatar
I have a 95 reg cab 5.0l. I have starter issues as well. I am eating a starter a year. Have tried all kinds from NAPA Acklands and Ford factory. No difference. To give you some history, everything was great until on night had to get to work. 40 below and my CB popped for plug in. Boost time from tow truck. Wouldn't go. Told him to give her 24 volts and I would be responsible if things went south. That got her going but ever since then, a starter a year. Could I have an issue with the soleniod on the side wall? Any other tips or suggestions?
Pike
pikeslayer is offline
clutch starter switch 1tonne Truck/SUV Talk 0 11-30-2009 11:43 PM
Remote Starter and/or Alarm MississaugaRanger Ranger Forum 8 01-19-2009 10:32 AM
Remote starter brauner_1 Audio and Electronics 1 12-16-2008 03:35 PM
Remote starter, who has one? fordtough.ca Truck/SUV Talk 12 09-27-2008 02:20 PM
starter help Frumpy Gas Engines 5 05-27-2008 10:26 PM
