tachometer - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 03-02-2011, 06:41 PM Thread Starter
matthew13sanderson's Avatar
Send a message via MSN to matthew13sanderson
tachometer
i have asked this on other forums and no one really can give me a straight answer, so hopefully one of you guys can help me i already know how to hook the tach up to the coil so dont sugest that to me!! :P
taken from my post on another forum
95 f150
i heard you can wire up an aftermarket tach to your wire harness even if you dont have a stock tach. so i took everything apart and im not totally sure what to do. in the pic you see a grey plug, which connects to the side with the oil pressure and temp, then the small black plug which conects in the middle of the cluster and then the brown plug which conects to the side with gas and volts.
the wire color for tach is usually green and there is only one solid green wire on all 3 of those plugs. the green wire is on the grey plug. so with that id assume that would be the wire id attach my tach to...only thing is, on my dads cluster (with a stock tach) his tach is on the right side, which would be the brown plug. so with that i would assume that the correct wire i need would be on the brown plug, because it to is attached to the right side of the cluster
so my question is if i should go ahead and wire my tach to the only solid green wire there (which is on the grey plug) or do i have to connect it to another color on the brown plug?
matthew13sanderson is offline
post #2 of 5 (permalink) Old 03-03-2011, 06:31 AM
Tach signal comes through on your brown plug. I'll look up the wiring in awhile. Why not just put in a factory tach. Change out the instrument cluster to one with a tach. It's plug and play.
Update...Tach signal wire is white with a pink tracer.
post #3 of 5 (permalink) Old 03-03-2011, 02:51 PM Thread Starter
thank you!! and i was thinking of putting a factory tach in but id rather keep it with the original km on it
post #4 of 5 (permalink) Old 03-03-2011, 10:27 PM
With a little work you should be able to keep the original speedo. I got lucky when I did mine because the truck i got it out of only had 1000km more that mine did. It also had a V8 and I have the I6. According to an Ethose Diagnostic Unit the tach is pretty much on the nose throughout the range. At least up to 3500 rpm.
post #5 of 5 (permalink) Old 03-05-2011, 10:24 AM
I swapped my speedo into one with a tach,works great.that way its current when they mark klms on sticker renewal..
Sticky58 is offline
