New Battery and ALt. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 08-27-2011, 03:30 PM Thread Starter
Well I guess its time to get back to work on the truck. The truck started a bad chirp last weekend and stalled on me twice. After checking things out a bad bearing in the alternator is the culprit (can feel the bearing grinding when I took the belt off and turned the pulley by hand). I just found a remanufactured 100 amp alt for 50 bucks in very good shape. Since I am doing that, I figured I would replace the battery and plugs (both original) while I'm at it. So at the moment I am counting my CT money, I should have enough to cover both since I've been saving it up for a new battery for a while. I try to remember to take a few pics to let every one now how it goes.
post #2 of 5 (permalink) Old 08-27-2011, 07:33 PM
Not sure about the V-6 models, but when I bought plugs for my Bronco V-8, the parts guy at NAPA told me to go across the road to the Ford dealer to buy them. He tells me that the 'Big 3" vehicles run better with factory issued plugs.
post #3 of 5 (permalink) Old 08-27-2011, 07:50 PM
yes always put recommended plugs
gilligan is offline
post #4 of 5 (permalink) Old 08-27-2011, 08:38 PM
Whatever you do don' get an Eliminator battery. They're crap now and you usually end up with a dead cell after about 2 years
post #5 of 5 (permalink) Old 08-28-2011, 03:21 AM
If you are a Costco member, you can get a Kirkland battery (manufactured by Johnson Controls)....I think that it has a 100 month warranty (prorated)...the first two or three years (can't remember which), it's a FREE replacement. They sell two batteries which fit most Rangers....the small one is around $65-$70 before taxes (CCA is like 600 or 650). The large one is around $90....get the large one if you can (large is stock battery size for Rangers in the late 90's...newer Ranger appear to get the small one)....CCA is ~950. I bought the small one for my 1996 B3000 since I am planning to sell the truck this year.
Dave
2010 Ford Ranger FX4
DavidY is offline
Battery maplesyrup F-150 2004 to 2008 Forum 12 06-23-2011 10:40 PM
second battery greger F-150 2004 to 2008 Forum 2 03-27-2010 10:50 PM
NEED HELP: BATTERY MJG Truck/SUV Talk 10 01-19-2010 07:14 PM
Alt Gauge Jumps! etniesbmx1 F-150 Pre-1997 Forum 9 11-04-2009 08:30 AM
NEED HELP: battery issue fordfan22 Other Ford Models 4 07-13-2009 08:24 PM
