NEED HELP: 4x4 issue - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 12-15-2011, 08:56 PM Thread Starter
dranged's Avatar
4x4 issue
i have a '94 Ranger. and it always seems like the front diff is engaged. can feel it on the drivers side. 4x4 works fine(i converted to manual locking hubs) but i disengage the 4x4, and still seems like its locked. what could this be? any help would be amazing. thanks in advance.
dranged is offline
post #2 of 6 (permalink) Old 12-15-2011, 10:27 PM
You unlocked the hubs? Or put the transfer case into 2 wheel drive? Or both?
post #3 of 6 (permalink) Old 12-15-2011, 10:35 PM Thread Starter
dranged's Avatar
both. with everything in 2wd. i can tell its still engaged. on drivers side.
dranged is offline
post #4 of 6 (permalink) Old 12-16-2011, 03:01 AM
make sure that hubs are unlocking, I've seen too much/toothick lube cause hubs to stay locked in. Ranger hubs are pretty fine little parts.
68Mercury250Ranger is offline
post #5 of 6 (permalink) Old 12-18-2011, 08:42 PM
+1 Just another point, is the transfer case shifter adjusted properly, or working?
post #6 of 6 (permalink) Old 01-09-2012, 07:20 AM
I had a similar problem with my 1990. What we found was that when the dealership serviced the front end they did not put the big split rings back onto the axles. These split rings hold the axles in place so everything works properly. I also had all sorts of problems with both electric and manual hubs. We finally found that my mechanis was using too much and too thick lube on them. Dave
Dantforth is offline
issue with my '08 SD T-LAV MRV Super Duty Forum 8 02-26-2011 02:40 AM
Transmission issue... herbz Driveline and Transmission 6 03-22-2010 12:31 PM
NEED HELP: Fx-4 tranny issue? villain Driveline and Transmission 6 11-08-2008 03:37 PM
DRL issue notmuchmud Lighting 5 07-05-2008 11:44 PM
