anyone gotten into a 4.6 swap? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 05-05-2012, 09:44 PM Thread Starter
FX4Ranger's Avatar
i just got a 04 f150 4.6 that ive already torn down and planning my build list now. i dont want to put it in my 07 ranger, but maybe in a similar 2wd one. im sure ford made a bit more room in the engine bay with the intoduction of the sohc 4.0. im sure a 4.6 will fit, ive heard the valve cover gets close to the brake booster and i can see why.. this thing is huge. im definatly getting rid of the truck intake, its massive.
07 FX4 Level II Ranger
89 Bronco II
Rust in Pieces
FX4Ranger is offline
post #2 of 12 (permalink) Old 05-06-2012, 12:30 AM
The 4.6 should fit cause I've seen the 5.8 ( 351 ) in a ranger, just use some lowering engine mounts gets the motor down in the truck more.
post #3 of 12 (permalink) Old 05-06-2012, 12:59 PM Thread Starter
FX4Ranger's Avatar
the 351 is actually smaller than a 4.6, the heads on this thing are massive. i knew it was a big engine, but i didnt realize just how big until i saw it sitting on my crane with the transmission on the back, id post pictures but i dont know how to XD
89 Bronco II
Rust in Pieces
post #4 of 12 (permalink) Old 05-06-2012, 02:30 PM
K.Strong's Avatar
I know the 5.0 swap is popular so the 4.6 should be ok.
K.Strong is offline
post #5 of 12 (permalink) Old 05-06-2012, 03:31 PM
Wiring is gonna be the issue. You're gonna need the ECU, and all under hood wiring
post #6 of 12 (permalink) Old 05-06-2012, 04:10 PM
The 4.6L is a wide deck engine, MUCH wider than the 5.0L and 5.8Ls actually. Hydroboost setup might be a consideration if you run into clearance issues there, but for the rest its just going to take lots of shoehorning. I'd personally be looking into Mustang accessories (intake, exhaust, ect) because they're bound to be much more compact than the truck stuff. I figure that if they can stuff one into a Sportrac or a Mustang, it should fit with a bit of luck into a Ranger. LR
post #7 of 12 (permalink) Old 05-06-2012, 06:35 PM
hihosilver's Avatar
What year was the motor? the later motors had PATS and you will need the matching gauges and ignition to start the engine or so I'm told
hihosilver is offline
post #8 of 12 (permalink) Old 05-13-2012, 10:20 AM Thread Starter
FX4Ranger's Avatar
It's from an 04 f150, and I got everything from the fan to the driveshaft including computer and wiring. I'm planning on ditching the intake, its massive I'm looking into various options, but more focused on building it first. Im thinking I may need to switch computers because I'm getting rid of the drive by wire, and depending how I build this, I think I need to go with a stand alone engine management system, as im upping compression and probably doing cams.. XD
89 Bronco II
Rust in Pieces
post #9 of 12 (permalink) Old 05-13-2012, 10:29 AM Thread Starter
FX4Ranger's Avatar
I would love to put up the pictures, but I have no idea how DX
89 Bronco II
Rust in Pieces
post #10 of 12 (permalink) Old 05-13-2012, 12:25 PM
hihosilver's Avatar
I think if you go with the stand alone engine management your going to save your self a whole lot of headaches with wiring and probably be able to make more power if your cams and such
To build or to swap.... LayinHp Diesel Engines 19 11-11-2011 11:39 AM
Engine swap Wolfsbane F-150 Pre-1997 Forum 8 02-19-2011 05:38 PM
engine swap gilligan F-150 1997 to 2003 /04 Heritage Forum 7 12-20-2010 02:15 AM
Interior swap ml878us Interior 0 09-21-2009 03:36 PM
Swap Meet Smokefan Ontario 7 08-14-2007 09:07 PM
