NEED HELP: Fan blowing cold air? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 05-28-2012, 05:22 PM Thread Starter
Since it was a nice hot day, I turned the fan on....it was blowing very cold air much like A/C. Switched it A/C and it appeared be blowing the same cold air. I think that I noticed this briefly last year....but didn't think much about it. Any thoughts? Warranty runs out at the end of this year.
Dave
2010 Ford Ranger FX4
DavidY is offline
post #2 of 8 (permalink) Old 05-28-2012, 06:11 PM
Confirm the problem, then dealer.
post #3 of 8 (permalink) Old 05-28-2012, 06:31 PM
Ive heard (and experienced) that if its on the defrost setting then a/c pump clutch stays ingaged..... switch it to reg fan and it should blow in the hot outside air....
mines does this and even puddles under the truck.... switching it over and it doesnt.
post #4 of 8 (permalink) Old 05-28-2012, 06:50 PM
Was the temperature rheostat turned to the coldest setting ?
Half the time on the hot days I get decently cold air without the A/C running so I don't bother punching the A/C button unless it gets too unbearable.
My other F150's did much the same.
No answer, I know, but hot day, cold air is better than hot day, hot air any.......um.....day.
post #5 of 8 (permalink) Old 05-28-2012, 07:14 PM Thread Starter
Yes, the temperature was rotated to the coldest setting. The setting was the two fans (high and low)....no defrost.
I will try it out again with various settings and see if I can replicate the issue. Thanks all.
Dave
DavidY is offline
post #6 of 8 (permalink) Old 06-12-2012, 08:08 PM
My 2010 does the same thing. I reported it to the dealer. They checked it and said it was OK. In fact it probably is OK. It was designed such that the AC actually runs in all but a few settings.
The reason for that is to ensure the clutch, compressor and seals are exercised all year round to prevent them not working when called upon during the warm seasons.
Off is one of the only settings where the AC is well and truly off.
Spring is offline
post #7 of 8 (permalink) Old 06-12-2012, 09:56 PM Thread Starter
A few Ranger owners have told me that the above is normal. Vent to the floor or thru the dash is fan only. Vent to both the floor and dash is A/C.
Dave
DavidY is offline
post #8 of 8 (permalink) Old 06-13-2012, 08:32 AM
If its too cold turn your temp up.
On more humid but not really cold days. I usually run the a/c but turn the temp up a bit. It will pull the humity out of the air before putting into the truck.
NEED HELP: heater blowing cold air westcoastranger Interior 18 11-28-2010 11:01 PM
Cold Air Intake 4x4truckguy Intake, Exhaust 2 04-06-2010 09:34 PM
cold air intake Tonka Truck Intake, Exhaust 3 08-20-2009 11:51 PM
NEED HELP: Cold Air intakes black on black fx2 F-150 2004 to 2008 Forum 16 07-25-2009 08:20 PM
Cold Air Intake? Coruptyed Intake, Exhaust 22 03-01-2008 05:26 PM
