Best Fluid for the M5OD-R1HD - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 10-29-2012, 06:41 AM Thread Starter
Maritime Storm's Avatar
Any find a fluid the allows for a smoother shift in the M5OD-R1HD than MerconV?
2009 Ranger Sport 2WD 4.0L/3.55:1/5spd Bone Stock.
Maritime Storm is offline
post #2 of 6 (permalink) Old 10-29-2012, 11:24 AM
anything in a synthetic ATF. I've used "Transynd" from Allison before but it is pretty expensive stuff. some of the newer nonsynthetic ATF has friction modifiers in it, those don't seem to help. definitely go with a synthetic ATF.
I took one of these apart a few years ago and someone had put in 80w90 .
I was wondering why it was so hard to shift.
[SIGPIC]
projects: all on hold for now
68Mercury250Ranger is offline
post #3 of 6 (permalink) Old 10-30-2012, 08:12 AM
Sorry, I misread. Carry on.
post #4 of 6 (permalink) Old 10-30-2012, 01:30 PM
Chienlaid's Avatar
HAHA LMAO
Chienlaid is offline
post #5 of 6 (permalink) Old 10-31-2012, 06:33 AM Thread Starter
I switched out the factory fill a couple years ago for Mobil Super Multi-ATF(Ford warrnty approved for Mercon V). No noted improvement in the shift quality. Later on a whim I, filled it with Mobil Super D/M and it shifts better but not as good as I feel it should be. That's why I'm wondering if someone found something better.
post #6 of 6 (permalink) Old 10-31-2012, 07:25 PM
I was told a pint of gear oil after filling it with mercon v helps out. The forks always get toasted so the little bit of over filling helps out.
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
5 speed fluid ?? joetalon F-150 1997 to 2003 /04 Heritage Forum 2 11-30-2010 03:45 PM
Brake Fluid Change JTSF150 Wheels and Tires 5 07-29-2010 10:31 PM
Synthetic Transmission Fluid Blue Oval Driveline and Transmission 5 02-15-2010 04:08 PM
Steering Fluid damion F-150 2004 to 2008 Forum 4 12-28-2008 06:45 PM
Fluid Temperatures tohi2care F-150 2004 to 2008 Forum 12 10-10-2008 11:48 PM
