2010 Ranger Wheels - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 09-08-2013, 06:41 PM Thread Starter
2010 Ranger Wheels
anyone know if any other vehicles use the same wheels that can fit on a 2010 Ranger 2wd?
From what I understand, due to the change from drums to discs in the rear, the older Ranger wheels won't fit the 2010s.
I'm looking for a set on the cheap for my Dad for winter. I've been browsing Kijiji but don't really know what will work without trying each one on.
thanks!
SCrew Lariat is offline
post #2 of 11 (permalink) Old 09-08-2013, 08:21 PM
The 5 x 4.5" (5 x 114.3mm) bolt pattern is common to a lot of vehicles, from Fords, Jeeps (Wranglers), Mazda, and some Dodges. The offset for 4wd and 2wd Rangers has been listed as Medium Offset for years, including 2010.
This list shows the last 5 years of Ford's patterns.
http://www.discountedwheelwarehouse...._Reference.cfm
I had 2006 rims on my 2008 Ranger, and just sold them last month to a guy with a 2009.
post #3 of 11 (permalink) Old 09-12-2013, 06:52 PM Thread Starter
thanks for your response.
I've ruled out oem rims of a 98 4x4 - the center hole is about 1/8" too small
the search continues
post #4 of 11 (permalink) Old 09-12-2013, 11:53 PM
TRNRBILT's Avatar
If I remember correctly when I was looking at rims awhile back the jeep ones may be the same bolt pattern but the center hole is to small for the hubs. (Oem jeep rims aftermarket are usually large enough)
TRNRBILT is offline
post #5 of 11 (permalink) Old 09-18-2013, 08:58 AM
Yesterday I tried a 16" rim from a Windstar. Didn't fit my 2010 Ranger 2wd.
Cheers!
Spring is offline
post #6 of 11 (permalink) Old 09-18-2013, 06:51 PM
TRNRBILT's Avatar
Just remembered a buddy had 16" crown Vic wheels on his 93 ranger and they fit. Not sure about on newer rangers.
TRNRBILT is offline
post #7 of 11 (permalink) Old 09-19-2013, 03:53 PM
I was told the older rims won't fit over the rear calipers on the 2010. At lest that's waht the dealer told me when I bought my truck. I had 15" rims from an Explorer that fit my 95 that I wanted to use for winter tires. The dealer said no go. Never tried them myself, got the truck in Feb and it was too cold to see if they fit.
1968 F100 428
2010 Ranger Xl 2.3
2008 Edge
jimmyk is offline
post #8 of 11 (permalink) Old 09-21-2013, 06:59 AM
Blue Oval's Avatar
I converted my '09 4WD from factory 16s to aftermarket 15s and can honestly say the front calipers are a tight fit. I had a look at a '10 with the rear calipers and the rims appear to have a unique shape in order to clear the calliper - could be a tough find.
Have you tried sourcing a steel wheel?
Blue Oval is offline
post #9 of 11 (permalink) Old 09-22-2013, 10:14 AM Thread Starter
I ended up finding a set from another '10 on Kijiji.
post #10 of 11 (permalink) Old 09-22-2013, 10:32 AM
Probably the best outcome to use like for like wheels from another '10. Good score.
2010 Ranger in N.S. K.Strong New Members Introductions 19 08-25-2011 10:19 PM
2010 F150 18"-20" Wheels 97350 F-150 2009 to 2014 Forum 8 08-20-2010 10:42 PM
2010 ranger parts? 3323 Ranger Forum 21 05-28-2010 07:18 AM
2010 Ranger Blue Oval Ranger Forum 13 05-15-2010 10:50 AM
NEED HELP: Bullitt wheels on 97 ranger alpine69 Ranger Forum 7 11-05-2008 11:59 PM
