NEED HELP: how to stop engine from revving. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 05-03-2014, 03:01 AM Thread Starter
Thumbs down how to stop engine from revving.
Hi, I've a 1989 2.3l ranger with a manual transmission,distributerless ignition, and fuel injectors. When I come to a stop the engine revs up for about 20 seconds or so and then idles down to a more bearable level (but still too high). It'll also rev up between shifts. I've checked my Haynes manual and I can't find anything in there that relates to my problem. I listened closely to the engine and I couldn't hear any air leaks. If anyone has any suggestions, I'll surely try them out. Thanks
watermellon is offline
post #2 of 6 (permalink) Old 05-03-2014, 03:15 AM
I like Fords Too's Avatar
if I were lookin at a front wheel drive mopar I'd say off hand either idle speed control motor or speed sensor
but your really just chaseing your tail without a way to read fault codes stored in your trucks computer
I like Fords Too is offline
post #3 of 6 (permalink) Old 05-03-2014, 08:02 AM
Check the clutch switch.
post #4 of 6 (permalink) Old 05-09-2014, 02:59 PM
That could be normal. my 95 2.3 did the same thing. Apparantly its the computer's way of acting like a dashpot on a carbed engine. Its supposed to keep the truck from stalling.
1968 F100 428
2010 Ranger Xl 2.3
2008 Edge
jimmyk is offline
post #5 of 6 (permalink) Old 05-10-2014, 12:02 AM
TRNRBILT's Avatar
My 89 2.9 does it everyonce in a blue moon too. Must be kinda normal
TRNRBILT is offline
post #6 of 6 (permalink) Old 05-10-2014, 01:35 AM
Vacuum leak.
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
NEED HELP: While driving my 2009 just wants to stop... why? will99 Super Duty Forum 6 03-26-2013 11:01 AM
This looks like a good place to stop Biz Photo and Video Gallery - Members Rides 12 01-28-2008 10:48 PM
