NEED HELP: What tire pressure for 245/75-16 tires? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 11-03-2014, 11:32 PM Thread Starter
Drivers side door label says 30 psi. My ex-Mazda B3000's door label was 35 psi.
Ran 32-33 psi in the past. I should do a chalk test, but it's winter so maybe next summer. Thoughts about running the tires at 35 psi in the winter or just leave it at 32-33 psi?
Just changed the tires to winter....Fountain Tire either didn't fill the tires up or just left it at 28 psi.
Thanks.
Dave
2010 Ford Ranger FX4
DavidY is offline
post #2 of 5 (permalink) Old 11-03-2014, 11:59 PM
I've had tire shops tell me to by the sticker on the door. But I go by the number on the tire itself. I know most of the smaller trucks come with "P" rated tires tires and eventually get replaced with placed with "LT" tires that have a higher pressure rating, like 50 psi.
Let the debate begin...
post #3 of 5 (permalink) Old 11-04-2014, 02:53 AM
my 245/75/16s are rated at 80psi, I run 70-75 on the rear and 65 in the front. this is a 7000lb 1 ton people van with a diesel engine.
if yours are rated for 35 psi run them at max in the winter time , they will have a smaller footprint and better traction.
[SIGPIC]
projects: all on hold for now
68Mercury250Ranger is offline
post #4 of 5 (permalink) Old 11-04-2014, 09:56 PM Thread Starter
Max tire pressure for the Generals is 44 psi. Probably play around 32-33 to 35 psi and see how the ride is.
Dave
DavidY is offline
post #5 of 5 (permalink) Old 11-05-2014, 02:56 AM
Dave
if you are worried about the ride not traction , stick with your present 32-33psi. any more pressure will make your ride more harsh. after Christmas put them up to max and you'll love the traction improvement. (if you get the snow!)
[SIGPIC]
Pressure washers KIETH F150 Care & Detailing 15 02-11-2013 08:56 AM
Exhaust Back Pressure Haley-Special F-150 1997 to 2003 /04 Heritage Forum 0 07-15-2011 09:20 AM
Canadian Nitto Tire dealer besides Kal Tire? joeyg Wheels and Tires 5 10-05-2010 07:34 PM
NEED HELP: oil pressure 89f150 F-150 Pre-1997 Forum 2 05-14-2010 03:51 PM
Tire Pressure - BFG A/T T/As Blue Oval Wheels and Tires 6 11-22-2009 02:45 PM
