Idle and cylinder 4 problem help please! - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 01-11-2015, 03:28 AM Thread Starter
first time posting here but i really need help, ive bought an 02 ranger, 4L v6 and shortly after the check engine light came on with a cylinder #4 and 5 misfire and a really rough idle while stopped or at low rpm and higher speeds and rpm the truck seems to be good, so i thought may have been a vacuum leak or something to do with the fuel system, so i checked:
intake manifold put new gaskets in
vacuum leak test
injectors checked
new plugs
checked spark
checked compression
spark plug cables
coil pack and plugs
cleaned the iac
took the valve cover off everything seemed normal
any feedback or info would be greatly appreciated, i know i can't be the only person with this problem!
jmack199 is offline
post #2 of 4 (permalink) Old 01-11-2015, 07:14 AM
I noticed that you had suspected the fuel system, did you check the pressure?
post #3 of 4 (permalink) Old 01-11-2015, 12:26 PM Thread Starter
Ya everything seemed to be normal , I'm so stumped as to what this could be ...
jmack199 is offline
post #4 of 4 (permalink) Old 01-11-2015, 02:50 PM
I like Fords Too's Avatar
usually on newer stuff the first thing to do is check for fault codes stored in the computer
I like Fords Too is offline
NEED HELP: 2.3l idle problem/ oil sending unit watermellon Ranger Forum 2 10-04-2011 07:08 AM
NEED HELP: Cylinder #5 missfire Dadbro F-150 2004 to 2008 Forum 5 04-26-2011 07:24 PM
Idle Problem countryboy Gas Engines 10 01-20-2010 02:31 AM
NEED HELP: Slave Cylinder Slave to Cylinder F-150 Pre-1997 Forum 3 12-09-2009 01:23 PM
Master Cylinder? truckguy94 F-150 Pre-1997 Forum 8 05-20-2009 11:23 AM
