NEED HELP: Removing power steering cooler... ok or stupid - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 04-27-2015, 11:07 PM Thread Starter
seanm's Avatar
The power steering cooler on my '98 Ranger is leaking. The cooler is both hard to get and expensive. I am pretty sure the cooler was part of the towing package and not standard.
I am contemplating just removing the cooler and bypassing it. I don't tow with the truck. I very very rarely have any sort of load in the box. I believe the most was 800 pounds of rocks once.
Thoughts?
seanm is offline
post #2 of 2 (permalink) Old 04-28-2015, 06:43 AM
R/R with something cheaper. It doesn't need to be original equipment. Use a small transmission cooler. Don't get rid of it with a bypass.
power steering fluid Fordie07 Driveline and Transmission 3 04-16-2015 09:36 PM
Power Steering Filter SCrew Lariat F-150 2004 to 2008 Forum 2 11-08-2011 01:46 PM
Power steering problem? 07rangersport F-150 2004 to 2008 Forum 13 05-05-2011 03:35 PM
bubbling power steering fluid?? 07harley F-150 2004 to 2008 Forum 4 05-23-2010 09:05 AM
tight power steering 1-800-bigtruck Sticky Tech/How to Section 6 03-07-2009 04:58 PM
