signal lights wont cancel - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 08-19-2015, 11:47 PM Thread Starter
hi all,i just bought a 2000 xlt 4x4 4L engine, the signal lights work good but they dont cancel,kind of annoying.i havent looked into it yet but would i have to be carefull of the airbag taking the steering wheel off and checking inside to see whats happening
McBride is offline
post #2 of 6 (permalink) Old 08-20-2015, 06:18 AM
No idea, but welcome, good bunch here, hopefully you'll get the answer you're looking for to help you out.
post #3 of 6 (permalink) Old 08-20-2015, 10:11 AM
Sounds to me like the multifunction switch is gone.
I know on F150's the steering wheel has to come off and yes be careful with the airbag.
The wire's going to the bag are very delicate. I recommend wrapping the airbag in a towel or something when you get it out and place it far away from where you are working on a flat surface.
post #4 of 6 (permalink) Old 08-20-2015, 11:29 PM Thread Starter
thanks guys,so if i unhook the battery i shouldnt have to worry about it setting off?
McBride is offline
post #5 of 6 (permalink) Old 08-21-2015, 12:21 AM
Yes you do. Unplug the fuses for the airbag and walk away for awhile. Then come back and unplug the airbag harness from the steering column. Do not under any circumstances allow a voltage to connect to the airbag harness. Static or otherwise.
post #6 of 6 (permalink) Old 08-22-2015, 12:41 AM Thread Starter
thanks for the replies,i am going to give it a go and see what i come up with
McBride is offline
NEED HELP: CD Player wont take the CD's? commanderjjv Audio and Electronics 5 01-06-2014 05:58 PM
04 f150 turn signal problem Mayhem F-150 2004 to 2008 Forum 3 10-19-2010 05:19 PM
Hazard lights and signal lights don't work Chezwesterson New Members Introductions 6 08-10-2010 09:50 PM
signal bulbs shelbyx1 Truck/SUV Talk 18 01-20-2009 01:38 PM
