2007 lift - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 19 (permalink) Old 03-11-2008, 08:14 PM Thread Starter
2007 lift
Does anybody know of a decent front lift kit available for an '07?
National 4WD can't find one anywhere.
If I have to do it myself I think I'll just order bigger gas shocks, maybe crank the torsion bar. From what I gathered from the internet, the shocks in my ranger are like a coil over but use a pneumatic spring concept inside. Are there any problems with getting longer shocks? The front tires will be closer together and all and I might need bigger bump stops, maybe an alignment but I can't find any major problems.
Don.Hagen is offline
post #2 of 19 (permalink) Old 03-11-2008, 08:29 PM
There is nothing up there on the market for new 4x4 Rangers
Yes Fabtech is working on one
post #3 of 19 (permalink) Old 03-11-2008, 08:55 PM
The only option you have at this time is a body lift
post #4 of 19 (permalink) Old 03-12-2008, 12:11 AM
SCREWDRIVER's Avatar
nonesense.... 01-05 kits will work. its been done. alot.
SCREWDRIVER is offline
post #5 of 19 (permalink) Old 03-12-2008, 12:17 AM
Yes with allot of grinding
You do have to modify 01 kit, do to front drive line position
post #6 of 19 (permalink) Old 03-12-2008, 01:16 AM
i talked to a guy with a 4" superlift from a 01-05, in his 07, and i asked him, did you have to do any modifications... and he said nope, bolted right up. just the front driveshaft was replaced with the superlift d/s. the RCD kit requires you to change yer rotors, to a smaller size that came on the 01-05 rangers
post #7 of 19 (permalink) Old 03-12-2008, 03:06 PM
Yes and agree, you need more parts than just a lift
The best way would be to PM Blackstock, They will tell you if it will work for you. I looked at front driveshaft on them, on the hoist and you can't just throw a lift on it. More parts are involve with it and that will include drive shafts and supports for them
post #8 of 19 (permalink) Old 03-12-2008, 06:29 PM
For a good quality lift I'd go with either Superlift or RCD. You'll be looking at $1600 + for the kit depending on what you get, but you get what you pay for. Don't forget to order a new front driveshaft too as the stock one will prematurely wear out... This goes for which ever kit you buy.
Good luck and post up some pictures when you get it done... I haven't seen a 06'+ Ranger with a lift like that on it yet around here... should look amazing when it's all said and done.
|Tommy_14| is offline
post #9 of 19 (permalink) Old 03-12-2008, 08:32 PM
post #10 of 19 (permalink) Old 03-12-2008, 11:49 PM
So they do exist
Sorry needamudpit
will they work on 08's and 09's too?
I was told by the dealer that they will not work
grrrrrrrrrrrrrrrrrrrrrr
2007 f150 stereo Bush_aholic F-150 2004 to 2008 Forum 13 01-13-2008 07:52 PM
Muddin' 2007 Video! Mud-Nut Photo and Video Gallery - Members Rides 10 12-19-2007 12:11 PM
2007 SEMA Show Blackstock Photo and Video Gallery - Members Rides 6 11-23-2007 10:22 AM
