brake signal wire for electronic brake controller - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 04-14-2008, 08:04 PM Thread Starter
hey guys and gals
installing a used electronic trailer brake controller from my fiance's old truck into mine. i'm just wondering where i would find the brake signal wire.
krazykanuk is offline
post #2 of 7 (permalink) Old 04-14-2008, 08:09 PM
Originally Posted by krazykanuk View Post
hey guys and gals
What year / model truck?
post #3 of 7 (permalink) Old 04-15-2008, 02:17 PM Thread Starter
sorry its a 94 ranger super/extended cab.
bought the truck used, not sure exactly which sub model it is.
post #4 of 7 (permalink) Old 04-15-2008, 02:44 PM
Do you need positive or negative for your controller
if positive you can pull it out of your rear break harness
If negative I think there is a limit switch beside your break pedal(or that maybe a positive)
but double check with a tester which one is positive wire
post #5 of 7 (permalink) Old 04-15-2008, 03:59 PM
If you need a positive..
My resources are listing.. But always test with a Digital Multi Meter first.
BRAKE lt. green (+) at brake pedal switch
Often times that wire runs down the side of the vehicle under the carpet.
I have no listing for a negative.
post #6 of 7 (permalink) Old 04-16-2008, 08:31 AM
Chienlaid's Avatar
I installed one on my 2007 Ranger and I spliced into the brake switch wire. Make sure you're splicing after the switch not before the switch or you're brakes will be on all the time. Brake controller works great, I pull a 17' Terry trailer with it.
This is what I used:
Chienlaid is offline
post #7 of 7 (permalink) Old 04-17-2008, 10:00 AM
http://www.the12volt.com
go to that site and click on vehicle wiring. I use this alot at work when I'm installing remote starts. Go to the switch above the pedal and solder in your connection. Those tap connectors are ok, but over time corrosion gets them.
red85 is offline
Brake dust fordtough.ca Care & Detailing 18 09-14-2009 10:15 PM
Parking brake shoes Fordwheeler Super Duty Forum 7 10-09-2008 04:28 PM
Brake help Fordwheeler Super Duty Forum 3 09-25-2008 05:56 PM
Emerg Brake Allway1 Super Duty Forum 0 03-27-2008 09:00 PM
