94 ranger trailer wiring problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 04-17-2008, 09:59 PM Thread Starter
first off i have searched the forums and havent found an answer.
1994 ranger 4X4 supercab
i am installing a 7 pin trailer light and brake system. i have the factory 4 pin wiring also there i have a 4 pin to 7 pin trailer light adapter. i know that the blue wire goes to my brake controller, and that the black goes to a fused 12V wire. and my orange/yellow wire goes to my back up lights.
Where can i find under the bed of the truck at 12V wire to splice into, as i would like to avoid if possible running a wire into the cab to pickup the 12V wire.?
hopefully doing the install tomorrow. please let me know when you can.
krazykanuk is offline
post #2 of 6 (permalink) Old 04-17-2008, 10:40 PM
There isn't probably a 12volt constant @ the back..
You'll most likely have to run up front to the batt or an open slot in the fuse block
post #3 of 6 (permalink) Old 04-17-2008, 10:52 PM Thread Starter
lovely i was trying to avoid that...
got a little lazy and was hoping to avoid that. is there a 12V that is powered only when the truck is turned on around there somewhere?
post #4 of 6 (permalink) Old 04-17-2008, 10:57 PM
You can use a relay..
It is triggered when the ignition is on giving you 12v power.. but when the ignition is shut off it takes away power..
post #5 of 6 (permalink) Old 04-17-2008, 11:07 PM Thread Starter
what size inline fuse should i use if i just wire it straight off of the battery? 15Amp?
post #6 of 6 (permalink) Old 04-17-2008, 11:33 PM
15 would be a min
I would run #10AWG wire for your Batt + and fuse it at 15 amps
Anybody on wiring ? Umaxman Audio and Electronics 2 05-25-2008 08:44 PM
power window wiring nnik F-150 Pre-1997 Forum 9 03-01-2008 02:39 PM
battery JB wiring removal?? lightning25 Audio and Electronics 1 08-28-2007 08:55 PM
