2011 Ranger lowering - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 1 (permalink) Old 01-26-2019, 03:14 PM Thread Starter
I would like to lower my 2011 Ranger sport a few inches. In looking at the back, i was going to remove the stock lift block from under the spring to above the spring. I did see that there are brake dampers on the top bolt of each brake caliper in the rear which would be very close to the spring if not hitting it after i lower it. I was thinking of replacing the dampers with bolts but I understand they provide a function to remove any squealing and other brake noises. Anyone tried this before and can you provide any advice?
Redrangersport is offline
Rear Suspension Lowering Kit fordtough.ca Suspension 40 07-08-2010 01:18 AM
Lowering Kit fordtough.ca Street Scene 9 02-04-2010 04:49 PM
NEED HELP: Rear Lowering Kits Bates88 F-150 2004 to 2008 Forum 10 03-02-2009 12:49 PM
Ground Force 4x4 lowering kit installed! screwsquat Suspension 31 03-01-2009 11:02 PM
Lowering the '08 AWD HD version truckpilot Wheels and Tires 22 02-08-2008 11:37 AM
