Sub woofer info - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 07-30-2008, 06:55 PM Thread Starter
Sub woofer info
Does anyone know if its possible to add a subwoofer to a factory deck in an 08 Ranger. The deck I have is fine for now. I would just like a little more thump. Any ideas or advice? Thanks.
post #2 of 7 (permalink) Old 07-31-2008, 12:14 AM
Yes a sub can be added to a factory system..
Hi-> Low level adapter is required to send low level signal to the amp..
also..
if the '06 is anything like the '08 then possibly this might be a good solution for you.
http://www.mtx.com/caraudio/products...NX99_specs.pdf
Hope it helps
post #3 of 7 (permalink) Old 07-31-2008, 02:20 PM
Spider 007's Avatar
Or just get an amp with a High Level input. That's what I have.
Spider 007 is offline
post #4 of 7 (permalink) Old 07-31-2008, 07:25 PM Thread Starter
Thanks. I like that down-fire box. Looks stock, not like some homemade thing.
post #5 of 7 (permalink) Old 07-31-2008, 11:24 PM
You can.. higher chance of inducing interference into the speaker wires.. Unless using twisted speaker wire running to the input on the amp..
post #6 of 7 (permalink) Old 08-20-2008, 12:27 AM
how do these sound.
god i miss the rock concert i used to have of a stereo system in my old blazer. but 5 thousand dollars later some hood rat stole it out of my vehicle.
these molded systems look good i want to keep my stock deck with the built in Serious ect 6x cd mp3 player ..
do these down fire setups hide well? can i still toss my gun back there in hunting season and not jab a hole threw it?
this comes with a MTX amp right?
i used to have a Bluethunder (stollen) and that was one of the best amps i ever used.
.. im pretty darn intrested in this if it can be hidden away and made not easy to steal.
leonard is offline
post #7 of 7 (permalink) Old 08-20-2008, 12:49 PM
Spider 007's Avatar
All of my wiring came with the amp and I never got any interference on it... I guess that's what you get when you buy quality! :icon_wink:
Need info on tuners Justin1635 Programmers and Tunes 2 09-23-2008 09:00 AM
Newb lookin' for some info the dougler F-150 2004 to 2008 Forum 5 09-12-2008 03:24 PM
Sub Woofer with Stock System sicksonicescape Audio and Electronics 2 02-09-2008 12:32 AM
Pacesetters, need info? Smokefan Wheels and Tires 3 11-08-2007 10:23 AM
