Tire Size Question - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 07-31-2008, 02:03 PM Thread Starter
dranged's Avatar
Tire Size Question
I'm picking up a '94 Ranger 4x4 this weekend and I'm looking at getting some rims/rubber for it. I'm going to go with the American Racing Outlaw II rims, 15x8. I was told on another forum that I could run a 31x10.50 tire on it, but when I went looking for tires they said that the biggest I could go is a 30x9.50. Anyone have 31inch tires on their Ranger? It's stock height.
dranged is offline
post #2 of 11 (permalink) Old 07-31-2008, 05:20 PM
that model of ranger have the most tire clearance in all ranger models,
i know someone with a ranger that year and he has 3" body lift and 35" tires, and another guy i know has no lift whatsoever and 32" tires
post #3 of 11 (permalink) Old 07-31-2008, 06:10 PM
dranged...this is from another board;
4x4 Rangers & all Explorer & Bronco II
For '83-'92 4x4 Rangers and all Bronco II, you can fit up to a 30x9.50R15 (235/75R15) using the stock rims.
On '93-'08 4x4 Rangers (and all Edge/Trailhead models), a 31x10.50R15 or a 265/75R16 will fit, depending on if you have the 15" or 16" stock wheels (16s are common on '98-'08)
'91-'01 Explorers (all) should be able to accommodate a 31x10.50R15 or 265/75R16 on stock rims.
post #4 of 11 (permalink) Old 08-03-2008, 07:04 PM
I have an 89 ranger 4x4 with a 3" body lift and i'm using 31x10.5R15
NFRanger is offline
post #5 of 11 (permalink) Old 08-03-2008, 07:57 PM
had 31-10.5/15 on my 93 ranger splash. no lift and no interference.
post #6 of 11 (permalink) Old 08-04-2008, 01:56 AM
you can fit 31x10.5 on after market 15" rims on a bronco ll no lift no scrubing problem with the bronco ll's is the ass end always sags
id say the 31's will clear on the ranger the front valance may need slight trimming
also be prepared to go through front 4x4 hubs if you offroad it unless you switch to the manual warn hubs which can take the torque
post #7 of 11 (permalink) Old 08-04-2008, 11:26 PM
i have 32x11.5r15's on my truck, but its raised 4 inches my friend ross. had 33x12.5R15's under his 93 ranger at stock. but a lil rubbing on the front bumber when getting in to driveways; thats all. i'd go wiht 31's or 32's. your choice.
post #8 of 11 (permalink) Old 08-05-2008, 01:28 AM
Cooker's Avatar
Heres a post I found for maximum tire sizes:
01-08
XLT 4X4, FX4, Level II, EDGE 2wd & 4X4(Sport newer models)(mild T-bar crank always recommended for leveling purposes, always remember to get an alignment)
* 15x7 stock suspension - 30x9.5x15, 31x10.5x15, 32x11.5x15, 33x10.5x15(T-bar crank recommended), 33x12.5x15(will need trimming and T-Bar crank)
* 15x8 stock suspension - 31x10.5x15, 32x11.5x15, 33x10.5x15(T-bar crank recommended), 33x12.5x15(will need trimming and T-Bar crank)
* 15x8 & 15x10 body lift or suspension lift - 32x11.5x15, 33x10.5x15, 33x12.5x15, 35x12.5x15(trimming also involved in multiple areas and T-bar max...), 325x60x15(31x12.9x15)
* 15x8 & 15x10 body lift AND 4-5" suspension lift - 33x12.5x15, 35x12.5x15(T-bar crank recommended, were applicable), *Anything larger at your own risk or T-bar max and trimming*
* 16x7 stock suspension - 255x70x16, 265x70x16, 265x75x16, 285x75x16(mild t-bar crank recommended but might not be needed.)
* 16x8 stock suspension - 265x75x16, 285x75x16(same as above) 295x75x16(t-bar crank recommended and maybe trim.)
* 16x8 or 16x10 body lift or suspension lift - 265x75x16(16x8 only), 285x75x16, 305x75x16, 315x75x16(trimming also involved in multiple areas and T-bar max...)
* 16x8 or 16x10 body lift AND 4-5" suspension lift - 285x75x16, 305x75x16, 315x75x16(T-bar crank recommended, were applicable), *Anything larger at your own risk or T-bar max and trimming*
____________________
01-08
XLT & XL 2wd
* 15x7 stock suspension - 215x75x15, 235x75x15, 235x60x15, 30x9.5x15, 31x10.5x15(may need to trim)
_____________________
98-00
XLT & XL & Sport 2wd
______________________
98-00
XLT 4x4, XLT Offroad, Trailhead(mild T-bar crank always recommended for leveling purposes, always remeber to get an alignment)(may want to also replace T-bars do to T-bar sag)
* 15x7 stock suspension - 30x9.5x15, 31x10.5x15, 32x11.5x15, 33x10.5x15(T-bar crank recommended), 33x12.5x15(will need trimming and T-Bar max)
* 15x8 stock suspension - 31x10.5x15, 32x11.5x15, 33x10.5x15(T-bar crank recommended), 33x12.5x15(will need trimming and T-Bar max)
* 16x7 stock suspension - 255x70x16, 265x70x16, 265x75x16, 285x75x16(mild T-bar crank recommended but might not be needed.)
* 16x8 stock suspension - 265x75x16, 285x75x16(same as above) 295x75x16(T-bar crank recommended and maybe trim.)
93-97 (Consult before adding tires, this is the tricky year)(may also need lift in rear depending on spring sag)
4x4 & 2WD (The 2wd and 4x4 front springs are the length and the shocks.)
* 15x7 stock suspension - 30x9.5x15, 31x10.5x15(may need to trim valance a little, if major spring sag wont fit)
* 16x7 stock suspension - 235x60x16, 235x75x16, 245x75x16(slight chance of trimming)
* 15x7 & 15x8 Leveling block or leveling spring - 31x10.5x15, 32x11.5x15( may need major trimming)
* 15x7 & 15x8 Leveling block or leveling spring & BODY lift or suspension lift - 31x10.5x15, 32x11.5x15, 33x10.5x15, 33x12.5x15(may need minor trimming)
* 15x8 & 15x10 body lift AND 6" suspension lift - 33x12.5x15, 35x12.5x15, *Anything larger at your own risk*
* 16x7 & 16x8 Leveling block or leveling spring - 245x75x16, 255x70x16, 265x70x16, 265x75x16(will need trimming with 16x8)
* 16x7 & 16x8 Leveling block or leveling spring & BODY lift or suspension lift - 265x75x16, 285x75x16(may need trimming), 305x75x16(may need trimming)
* 16x8 or 16x10 body lift AND 6" suspension lift - 285x75x16, 305x75x16, 315x75x16, *Anything larger at your own risk*
Cooker is offline
post #9 of 11 (permalink) Old 08-07-2008, 05:00 PM Thread Starter
dranged's Avatar
Thanks a lot.
dranged is offline
post #10 of 11 (permalink) Old 08-08-2008, 12:29 AM
mitchbtu's Avatar
I just got offered, and bought a set of 4 Michelin 31 x 10.5 x 15 XRadials with 65% meat left for $50.00
Do I need to do anything special to get them to be plug and play? Also will they affect the standard wear and tear the truck would get on regular size tires? I can wait to get off road with them once they are installed... Cooker, Needamudpit, and Ruggedranger feel like a off road trip?????
mitchbtu is offline
NEED HELP: Tire size. skeg100 Wheels and Tires 3 11-06-2008 05:47 PM
Speaker Size Slim188 Ranger Forum 13 10-11-2008 11:33 AM
How to correct the tire size in the computer Bruicer Wheels and Tires 3 09-02-2008 04:48 PM
Speakers size ? Umaxman F-150 2004 to 2008 Forum 7 12-28-2007 03:31 PM
