fog light with High beam - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 09-04-2008, 02:35 PM Thread Starter
I wonder how to get my fog light working with my high beam.I tried pretty much everything list on the internet from bending pin from the fog light relay and get permanent ground (result cost me 28$ to replace it) to spice wire together from the smart junction box ...actually I did not try this one as the wire are not the same color.There is nothing really for 08 ranger most is for f-150 or older ranger
GT cobra is offline
post #2 of 3 (permalink) Old 09-04-2008, 04:05 PM
Install some offroad lights behind the grill then you don't need high beams.
post #3 of 3 (permalink) Old 09-04-2008, 05:38 PM
Install a relay that will energize when highs go on and power up fogs
use a 30amp contact rated relay and feed them directly from the battery through a 30 amp fuse
Use NC (normally close) contact for regular fog operation and connect Power from the battery to the NO (normally open) contact this way you can have fogs with and with out High beams
97-03 driving/fog lights klewis F-150 1997 to 2003 /04 Heritage Forum 5 01-22-2012 09:40 PM
NEED HELP: Question about 08' ranger h10 style fog lights RichmondRanger Ranger Forum 5 10-08-2008 10:17 AM
How to wire a Fog/ Driving light relay SKRWZ Sticky Tech/How to Section 2 09-26-2008 01:32 PM
Headlight Beam Pattern tohi2care Lighting 2 02-16-2008 12:52 AM
