Question For RuggedRanger15 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 09-14-2008, 10:17 PM Thread Starter
Send a message via MSN to TaggyTagz
Hey man, just saw your pics of your drive with the 33's on your truck. That looks awesome, gives me good images similar to my truck too.. exact same truck, 5 speed and all, except I have a leer cap... but now I want the big beefy tires and a lil extra height to get rid of that ... mini vanish look I've got .. I want 33's but really dont' wanna spend $$ on a susp lift, or even body lift.. I've looked at torsion crank, and a leaf spring lift or blocks in the rear to get a couple inches to fit them in.. What have you got done,a nd how tight a fit is it?? Cheers
EDIT: Just saw a couple other posts by you (RuggedRanger). Just torsion and a shacklelift.. coupel someone explain what shackle lifting involves?? Thanks
TaggyTagz is offline
post #2 of 6 (permalink) Old 09-15-2008, 12:00 AM
SCREWDRIVER's Avatar
the shackle lift uses the Chevy fullsize drop shackles, flipped they lift our trucks 1-2 inches... depending on the amount of drop they are meant to give the Chevy. Belltech 6700's are 1" (i think) and the belltech 6400's are 2".
2oo5 F~15o Supercrew 4x4
SCREWDRIVER is offline
post #3 of 6 (permalink) Old 09-15-2008, 12:07 AM Thread Starter
thanks for the help. now i just need to learn the best method for a torsion crank.
post #4 of 6 (permalink) Old 09-15-2008, 12:53 AM
RuggedRanger15's Avatar
Send a message via MSN to RuggedRanger15
easiest if you jack up your front end, but if you are strong enough you can do it without, or if you have a long wrench that makes it easier.
2008 Ranger Sport 4x4|Grey|5-spd stick|4.0 SOHC|35"x12.5" BFG KM2s|15" Daytona Rock Crawlers 15x10's|K&N CAI|Magnaflow Catback|Truxx AAL's|3" PA Body Lift|Custom Bumper|Custom Tow Hooks|Bilstein 5100's
RuggedRanger15 is offline
post #5 of 6 (permalink) Old 09-15-2008, 12:55 AM
I did mine with a 3/8 ratchet.
post #6 of 6 (permalink) Old 09-15-2008, 10:47 AM
mitchbtu's Avatar
I also did mine myself , but it is easier if its jacked up....
mitchbtu is offline
NEED HELP: Question Denis254 Ranger Forum 5 11-16-2008 01:26 AM
Question!! 1white08fx2 F-150 2004 to 2008 Forum 14 04-13-2008 09:42 PM
