Possible Bent Axle? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 09-21-2008, 07:10 PM Thread Starter
Possible Bent Axle?
Just wondering if anyone has come across troubleshooting a bent axle. I strictly drive my truck on the highway to Fort Mac. and back to Edmonton and for some reason i have an issue with the Left rear wheel assembly. I've already switched tires from front to back and that has not fixed anything. I'm not sure if it is a wheel bearing or maybe something in the Diff. My wheel seal is not leaking and the brakes at the rear axle are fine. If anyone has experienced this problem already please inform me. Thanks
RangerBoy is offline
post #2 of 11 (permalink) Old 09-21-2008, 10:57 PM
I had a bent axle in my 03 ranger.If you jack up the rear end and then spin the wheels (either by hand or by the motor),you should see the wheel wobbling.Then remove rim and repeat.No wobble = bent rim.Still wobbling = possible bent axle.Hope this helps you narrow down the problem.Also ALWAYS exercise caution when using jacks. And use jack stands.And having an assistant is not a bad thing either.With a cell phone.Play safe.
mud flies is offline
post #3 of 11 (permalink) Old 09-21-2008, 11:18 PM
i ended up with a bent axle on my 93 ranger also. thought it was a rim, because you could see a slight wobble when driven. swapped that rim/tire to the front and it was still there, so new axle and all was good. what exactly are you experiencing? noise? wobble? tire wear? some symptons would help us out.
post #4 of 11 (permalink) Old 09-22-2008, 12:49 AM Thread Starter
Bent Axle
Yeah some of the symptoms i had were a very bad shake inside my truck, the steering wheel seemed to not shake at all or not that bad ,so that pretty much eliminated the front end. The center support bearing seemed a little sloppy but I didn't think that would cause the tire to wobble like it is doing.
post #5 of 11 (permalink) Old 09-25-2008, 11:34 PM
SCREWDRIVER's Avatar
yup... like mud flies said... basically the best way to tell. I had a bent axle on my 07 Ranger... it was not pretty.
2oo5 F~15o Supercrew 4x4
SCREWDRIVER is offline
post #6 of 11 (permalink) Old 10-01-2008, 02:47 AM
...so what was the deal? bent axle?
post #7 of 11 (permalink) Old 10-01-2008, 07:49 AM
I wanna know what in the hell you guys are doing to bend axles.
post #8 of 11 (permalink) Old 10-01-2008, 09:59 AM
mitchbtu's Avatar
Wow, I also wanna know how you guys are bending your axles. I will avoid bending mine if possible. Rangerboy! So????? As Screwdriver said, whats the scoop????
mitchbtu is offline
post #9 of 11 (permalink) Old 10-01-2008, 03:07 PM
mine was donuts through mud...and there was something...(stumpish or rockish like) under the mud...and I smoted it with my truck lol
post #10 of 11 (permalink) Old 10-01-2008, 03:11 PM
Ouch, that sucks
So what happen with your RangeBoy
Ranger axle needed J.P. (Mount hope) Ranger Forum 25 10-17-2008 11:30 AM
Remove rear axle (How to) J.P. (Mount hope) Ranger Forum 4 10-16-2008 03:30 PM
Axle Seal Roadwarrior Driveline and Transmission 8 04-10-2008 11:09 PM
04 up f150 axle upgrade 1234 Wheels and Tires 28 02-13-2008 11:38 PM
AXLE CODE DECODER fordtough.ca Sticky Tech/How to Section 0 11-15-2007 06:38 PM
