Tranny Solenoid confusion - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 05-28-2009, 12:02 AM Thread Starter
So I'm still having issues with my '99 4.0 4X4 in the transmission area. I bought a shift solenoid, pulled the tranny pan and found that there are 4 solenoids. the 2 outter most are completely different and the 2 inner most are identical.
From front of the truck to the back I assume that they go in order of 1st gear, 2nd, 3rd, 4/5.
If someone can confirm this it would be greatly appreciated as the solenoid that I bought matches the two in the middle. The only other downside now is to truly figure out which one needs to be replaced.
I'm trying to load a pic I took but seem to be having some issues.
Nick
99danger_ranger is offline
post #2 of 9 (permalink) Old 05-28-2009, 03:36 PM
what shift solonoid are you wanting to replace?
post #3 of 9 (permalink) Old 05-28-2009, 08:04 PM Thread Starter
Thats the problem, the dealership I brought it to never told me. They wanted to charge over $700 to replace it. (that included removing and checking the valve body)
post #4 of 9 (permalink) Old 05-31-2009, 12:57 AM
what are the symptoms the truck is experiencing?
post #5 of 9 (permalink) Old 06-01-2009, 12:09 AM Thread Starter
Everything is inconsistent.
It shutters in 1st gear when trying to accelerate, like its not properly in gear.
Sometimes I don't have 5th gear or 4th.
If I pull over, shut it down and start it again numerous times it will all go away and I will be able to make it home.
post #6 of 9 (permalink) Old 06-01-2009, 03:51 PM
the shudder could be a tcc solonoid not releasing,did they pull any codes or do line press tests?
post #7 of 9 (permalink) Old 06-01-2009, 05:59 PM Thread Starter
I have checked the codes on a buddies code reader and all that comes up is P1747. I don't know if they did a line press test
post #8 of 9 (permalink) Old 06-02-2009, 04:09 PM
the p1747 is a epc(line press cont solonoid)open or shorted,it's the 4th solonoid on the side of v/b with 4 solonoids,it will cause low line press,limited eng power and 1-3 shifts missing,and lock up slippage.
post #9 of 9 (permalink) Old 06-02-2009, 11:35 PM Thread Starter
I assume thats fourth from the front. and unfortunately not the one I already bought. Hopefully the dealership will take back the one I have.
tranny Q. rangerT Ranger Forum 14 10-11-2008 06:38 PM
Which Tranny rebelk Driveline and Transmission 3 08-12-2008 11:12 PM
Which Tranny Roadwarrior Driveline and Transmission 5 08-10-2008 04:34 AM
tranny 4x4.0 Driveline and Transmission 2 03-17-2008 07:44 PM
