NEED HELP: lift kit source - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 09-30-2009, 10:34 PM Thread Starter
Red face lift kit source
I am looking to source a torsion key kit for the front of my 09 FX4 ranger to add 2-3inches, I will add leafs and a block if needed to stiffen and lift the rear. I found some on US sites but would prefer a trusted Cad. dealer.
Carl534 is offline
post #2 of 8 (permalink) Old 09-30-2009, 11:26 PM
Stay away from torsion keys. They put ball joints and cv shafts at really bad angles. Just crank your torsion bars up on the stock keys. Or get a body lift.
post #3 of 8 (permalink) Old 09-30-2009, 11:52 PM
+.1
post #4 of 8 (permalink) Old 10-01-2009, 12:24 AM
Seb_L's Avatar
Get used keys from a 1998-2007 Ranger at a Junkyard, internet, stealership. Install and Crank. I got about 4.5" with this.
2008 Ranger FX4
Seb_L is offline
post #5 of 8 (permalink) Old 10-01-2009, 11:37 AM
Chris.S.'s Avatar
Originally Posted by SKRWZ View Post
+.1
For the 09 he does need new keys, as of 08 they were clocked back and you can't crank them far enough to get the desired lift.
4.5" sounds like a lot (you're watching your cv angles right?) but that's what I'm talkin about. Gotta swap in older keys to get a good crank...
Just some dude from BC...
Chris.S. is offline
post #6 of 8 (permalink) Old 10-01-2009, 09:11 PM
If he only wants 2" he can get that on his stock keys. But yes 3-3.5" no problem with 07 and earlier keys.
x2 on 4.5"
post #7 of 8 (permalink) Old 10-01-2009, 11:17 PM Thread Starter
Thanks everyonr I was looking to do somethng similar as to my 86 ranger where I added the heaviest spring listing for a loaded version and this gave me about 2.5" without having to deal with brakeline issues etc. Then in the rear i put in 4 more leafs and this levelled it out, and then another 2.5 came from using square tubing to make the body mounts taller. This let me run a larger tire and eliminated problems with heavy loads and gave decent off road ability. The biggest problem was the stock axle ratio was 3:45 and the 2.9 was hard ofuel and barely used 5th gear. I swapped axles to a 3:73 and it was better then when I finally had found a 4:11 set I had other cab issues and took it off he road and recently bought the new one with the 4:11 locking and 5spd so that small mods would be easier. Can someone explain to me what is involved in adjusting my torsion keys to gain some height? I find the rear is soft and intend to add more leafs there.
Carl534 is offline
post #8 of 8 (permalink) Old 10-01-2009, 11:46 PM
http://www.therangerstation.com/tech...orsionBar.html
Ready Lift torsion key lift Ford00XLT F-150 1997 to 2003 /04 Heritage Forum 6 01-16-2010 11:33 PM
Looking for a good Ranger Lift Kit Rangoid Ranger Forum 7 08-30-2009 02:41 AM
Lift kit question?????? Nailbanger Off Road 8 02-19-2009 10:25 PM
NEED HELP: "Ready Lift" Levelling Kit Bong80 Truck/SUV Talk 5 10-31-2008 06:57 PM
lift kit fabrication details silverfox Wheels and Tires 2 12-07-2007 03:16 PM
