what size Winter tires - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 10-01-2009, 11:48 AM Thread Starter
What size winter tires would you guys suggest putting on a stock 2009 4x4 ranger sport? Right now i'm sporting the 255/70/16's.
Thanks!
i.feature is offline
post #2 of 9 (permalink) Old 10-01-2009, 12:37 PM
A suggestion: If you plan on using winter rims (and you should) try to get a skinnier version than stock, then get as tall and skinny tire as you can fit on your truck. Any good tire shop should be able to help determine what will fit.
post #3 of 9 (permalink) Old 10-01-2009, 12:42 PM Thread Starter
Do to finances i'll probably have to use stock rims this year. Would 245/70R16 fit on these rims without issue? Or would i be better off going up 265/70R16?
post #4 of 9 (permalink) Old 10-01-2009, 03:55 PM
try and get a winter tire with the same overall height as to not throw off your speedo calibration as a lot of systems on the truck use this info.
post #5 of 9 (permalink) Old 10-01-2009, 05:01 PM Thread Starter
The difference between 245/70/16 and 25570/16 would be negligable though correct?
post #6 of 9 (permalink) Old 10-01-2009, 05:28 PM
Correct.
Tire size calculator:
http://www.1010tires.com/tiresizecalculator.asp
post #7 of 9 (permalink) Old 10-01-2009, 05:33 PM Thread Starter
Originally Posted by b4000 View Post
Thanks for that. So 1.8ish differential in speed. I think thats likely satisfactory.
post #8 of 9 (permalink) Old 10-01-2009, 06:28 PM
I was just talking to a buddy that works at the Ford dealer. I ordered a set of winters for my dads RAV4. I had to change tire size to get a studable tire. The new size is 1.75% difference. Buddy told me "Have to stay below 3.0% difference because of ABS issues".
post #9 of 9 (permalink) Old 10-05-2009, 01:49 AM
245/75R16
Adam06FX4 is offline
looking for winter tires i.feature Ranger Forum 13 03-28-2009 01:06 PM
Winter Tires for the Ranger Writerz Block Wheels and Tires 4 11-18-2008 07:58 PM
What size tires are you running on factory rims? fordtough.ca Wheels and Tires 4 05-01-2008 08:16 PM
winter tires? excursionking Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 1 12-17-2007 10:06 PM
My Winter rims and tires fordtough.ca Wheels and Tires 4 11-16-2007 08:41 PM
