more hid problems - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 10-28-2009, 09:58 PM Thread Starter
more hid problems
ok so ive checked all the forms and never seen this weird problem i drive a 2008 ranger sport i installed hid's today and i know about the drl problem but when im driving with them on with the switch on they work great for about a minute while driving then they slowley dim and shut off or only one will shut off but if im idling they run fine anyone got any ideas ? thanks
08ranger is offline
post #2 of 12 (permalink) Old 10-29-2009, 01:46 AM
un plug the drl.
post #3 of 12 (permalink) Old 10-29-2009, 02:49 AM Thread Starter
Do you mean unplug the drl relay because there isent one or do you mean unplug the drl mod if so do you know where I can find it
08ranger is offline
post #4 of 12 (permalink) Old 10-29-2009, 12:16 PM
un plug the relay, and see, i un pluged mine so i could drive with just the parking lights and the for lights on.
post #5 of 12 (permalink) Old 10-31-2009, 04:34 AM Thread Starter
Problem solved I needed a LCM (load control mod)
08ranger is offline
post #6 of 12 (permalink) Old 11-01-2009, 01:59 AM
Denis254's Avatar
Send a message via MSN to Denis254
how you do that? and what is a LCM ?
2008 Ford Ranger FX4 4.0
Denis254 is offline
post #7 of 12 (permalink) Old 11-01-2009, 04:54 AM Thread Starter
Well since rangers put out half ass power instead of constant 12v power a load control mod (LCM) allows it to run constant 12v so no flickering unless using drl. It cost me 10 bucks a side and they plug right in to the hid kit so far worth the extra 20
08ranger is offline
post #8 of 12 (permalink) Old 11-01-2009, 06:49 PM
good stuff.
post #9 of 12 (permalink) Old 11-03-2009, 11:16 PM
where did you find this drl relay? where did you buy the lcm?
lone2K5ranger is offline
post #10 of 12 (permalink) Old 11-05-2009, 01:47 AM Thread Starter
I never found any relay for the drl they arnt in 08 rangers as for the lcm I got from my hid guy in Scarborough. Where ever you got your hids from they should have lcm to plug right into your kit if not let me know and I'll see what I can find out
08ranger is offline
HID Lights??? ChadH Lighting 8 11-24-2008 12:57 AM
HID install Northern Supercrew Lighting 20 09-29-2008 12:14 AM
HID problems BMac Lighting 7 08-18-2008 11:40 PM
HID Lights... fordtough.ca Lighting 10 06-18-2008 10:42 PM
