new truck/bad bearing - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 10-30-2009, 02:24 AM Thread Starter
hello out there
just bought 06 fx4 level2 . upgrade from my old 94 xlt 4x4.
first timer on a forum of any kind... looks like a good place to get info,..
fr.wheel bearing was wasted at 63k any one else seen this? I only did the one side that failed..? should I do both?
blk&wht is offline
post #2 of 8 (permalink) Old 10-30-2009, 06:38 AM
Maritime Storm's Avatar
No. Their is no telling when or if(more likely when) the other will fail.
Maritime Storm is offline
post #3 of 8 (permalink) Old 10-30-2009, 10:29 AM
murray99's Avatar
I had to change my left front as well this summer. Easy to re%re about 20 minutes...
murray99 is offline
post #4 of 8 (permalink) Old 10-30-2009, 10:43 AM
If it was my truck I'd do both even if the other one is fine doing both gives you piece of mind then you know there ok
post #5 of 8 (permalink) Old 10-30-2009, 01:19 PM Thread Starter
my next ? is about my front axle witch to my surprise spins all the time . when did ford change this? advantages? disadvantages? seems to me that locking hubs would save wear and tear if you don't mind getting out in the mud..
blk&wht is offline
post #6 of 8 (permalink) Old 10-30-2009, 10:44 PM
Blue Oval's Avatar
advantage: you can engage 4H at pretty much any speed as the front end is already turning at speed
disadvantage: front end turn all the time so fuel mileage suffers
Blue Oval is offline
post #7 of 8 (permalink) Old 10-30-2009, 10:53 PM
My passenger side wheel bearing went at 70k. I had it replaced under warranty
post #8 of 8 (permalink) Old 10-31-2009, 01:19 AM
Also, less parts = less to break, and cheaper to build.
It would be nice if there were an easy aftermarket solution to put locking hubs on it, though. I don't think you can just install Warn hubs on this set up.
Wheel Bearing maybe murray99 F-150 2004 to 2008 Forum 12 06-04-2009 01:18 AM
Nice truck....Bad pic Bush_aholic Photo and Video Gallery - Members Rides 18 04-18-2008 10:33 AM
Driver's side wheel bearing MRGADGET Wheels and Tires 14 04-04-2008 06:28 AM
wheel bearing failure canadian redneck Super Duty Forum 6 03-06-2008 01:59 AM
