NEED HELP: 2000 Ford Ranger-Wheel Bearing... - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 11-10-2009, 07:50 PM Thread Starter
Exclamation 2000 Ford Ranger-Wheel Bearing...
Hey Guys,
I have to replace my front wheel bearing...believe it is the passenger side clunking trying to save some some shop costs and do it myself. Just looking for some advice and if it is easy enough for me to do myself.
Scott
mustangracer5_0 is offline
post #2 of 3 (permalink) Old 11-11-2009, 12:18 AM
2wd or 4x4? it make a big difference
all the same, jack up the front end and check what's loose and clunking before you go and order party. upper ball joints/control arms are super common to be pooched. tie rods can go too, and so can stab links.
Varsity Tyler is offline
post #3 of 3 (permalink) Old 11-11-2009, 01:27 AM
you would be better off checking the front end first,most wheel bearing failures won't produce a "clunk"(unless completly fubared)a common cause of front end clunks on a ranger is the sway bar end links loosening/or wearing through the lower control arm.
Wheel Bearing maybe murray99 F-150 2004 to 2008 Forum 12 06-04-2009 01:18 AM
Driver's side wheel bearing MRGADGET Wheels and Tires 14 04-04-2008 06:28 AM
wheel bearing failure canadian redneck Super Duty Forum 6 03-06-2008 01:59 AM
Ford Excursion owners manuals (2000 - 2005) excursionking Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 0 11-30-2007 11:50 PM
