Battery Dies! - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 11-23-2009, 12:04 PM Thread Starter
Battery Dies!
Since I bought my 2008 Sport, I have started to work out of town. I usually get home every second weekend or so.
The truck is pretty well bone stock. No A/C and no power anything behind a 3.0l with automatic transmission.When the Ranger sits while I am away (2 weeks outside) the battery is dead and it won't start without a jump or the battery being charged. Yesterday I hooked up the charger and it showed only 48% charge when I started.
I have an after-market alarm/remote start system, but have not been engaging it to see if that may be causing the power draw. The battery still dies after two weeks. This has been happening for a year.
The kicker is that most of us drive our trucks daily so finding someone else with knowledge of this problem may be tough. Any ideas or does anyone know if this is a problem?
Cowboy is offline
post #2 of 12 (permalink) Old 11-23-2009, 02:36 PM
when you go away start pulling 1 different fuse each time. This will eventually tell you where the draw is coming from
post #3 of 12 (permalink) Old 11-23-2009, 03:45 PM
even better put an amp meter in series with the neg cable you should have 20-80mA draw(.02-.08amps)if it's higher than that start pulling fuses to find what is drawing current.
post #4 of 12 (permalink) Old 11-23-2009, 11:02 PM
Matty's Avatar
Even though you are not arming your alarm it will still draw power if the alarm is connected directly to the battery terminal.
The first year I left my Mustang in the garage over the winter the alarm did a weird chirp intermittenly even though it wasn't armed. After that the battery was DOA. I pulled the direct feed for the alarm off of the battery and the battery has been fine ever since.
Maybe this is your problem as well.
Matty is offline
post #5 of 12 (permalink) Old 11-24-2009, 09:31 AM Thread Starter
Wow, these are great ideas to trouble-shoot the problem. Thank you all!
Cowboy is offline
post #6 of 12 (permalink) Old 11-24-2009, 02:16 PM
Its' your alarm system. There is always a draw of power. My Superduty does the same thing with the command start security. I work in the bush 2 weeks in and 2 weeks out. It wasn't until I turned off the toggle switch for the command start that my batteries didn't die.
2001 7.3 SuperDuty Lariat
AFE Stage II Cold Air Intake
PHP Tunes , Autometer Gauges
Zoodad Mod, NC Hornet's CCV Mod
4"SS MBRP Exhaust
ITP Overboost Annihilator
Roada Deco Positive Air Shutoff
NADP Heavy Hauler Transmission
6 liter Trans Cooler
BD Power Auxiliary Trans Filter Kit
Diesel Site Coolant Filtration System
PSD911 is offline
post #7 of 12 (permalink) Old 11-25-2009, 06:39 AM
Maritime Storm's Avatar
I'll behave and not getted started on how evil alarms & remote starters are.
Maritime Storm is offline
post #8 of 12 (permalink) Old 11-25-2009, 07:49 AM Thread Starter
That is probably it. I think I will install a Battery Tender under the hood so that it will stay charged - and I can plug my block heater in at the same time.
Cowboy is offline
post #9 of 12 (permalink) Old 12-19-2009, 10:14 AM
I just had the battery in my 08 Ranger Sport replaced, at the most it sits 1 or 2 days. I only have about 25500km on it and not aftermarket electronics.
Padrino73 is offline
post #10 of 12 (permalink) Old 12-20-2009, 09:30 AM
My truck sits for 1-4 weeks on average since I'm in basic training, starts every time.
2009 GO Ranger
Snepy is offline
NEED HELP: BATTERY MJG Truck/SUV Talk 10 01-19-2010 07:14 PM
NEED HELP: battery issue fordfan22 Other Ford Models 4 07-13-2009 08:24 PM
Optima Battery Lord Helmut F-150 2004 to 2008 Forum 5 12-19-2008 01:16 PM
battery issue stevet F-150 2004 to 2008 Forum 3 12-07-2007 10:58 AM
battery JB wiring removal?? lightning25 Audio and Electronics 1 08-28-2007 09:55 PM
