NEED HELP: Modification Ideas - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 12-16-2009, 10:07 PM Thread Starter
Modification Ideas
I need some modification idea's for my 2006 ford ranger. Or i want to make it more an offroad truck so i need idea's.
This is my first post so i hope theres not a thred like this.
risk is offline
post #2 of 11 (permalink) Old 12-16-2009, 10:34 PM
lift it bigger tires then a custom front and rear bumper
im still working on my front bumper and am trying to think of something to do for the rear but this truck is just for off road cant really drive it too much on the road this is my 1999 ranger
lonerangerxlt is offline
post #3 of 11 (permalink) Old 12-17-2009, 10:05 PM
Chris.S.'s Avatar
Good cheap mods:
Torsion twist (search it)
Upsize your tires (265/75 should fit with a small lift)
Have you got good skidplates underneath?
Custom bumpers as mentioned
Beyond that it's all about how much you want to spend and hard you want to go...
Just some dude from BC...
Chris.S. is offline
post #4 of 11 (permalink) Old 12-17-2009, 11:54 PM
ya well with the newer tuck the torsion bar twist will work unlike my tuck and that would give you a 2 inch lift dont go more than 3inch it will f#@k up your half shafts but my torsion bar twist never worked it was all the same so i think the never trucks should work then alittle lift in the rear and newer or bigger tires and you can go off roading but i always went off roading in my that was stock when i got my truck
post #5 of 11 (permalink) Old 12-18-2009, 12:17 AM
theres a lot you can to do a ranger to make it more of a mudd truck
post #6 of 11 (permalink) Old 12-18-2009, 04:37 PM
Upgrade tires, lift, depending how serious of offroading you plan on lockers, skid plates or even a solid axle swap there are so many possibilites.
post #7 of 11 (permalink) Old 12-18-2009, 08:21 PM
All depends on your budget. Cheapest way is to crank the torsion bars with either blocks, an add a leaf or shackels in the rear, then you can get bigger tires. You can also do a body lift, alot of people don't like them but I have never heard of a reason for not likeing them. I had one on an 02 150 I had and it wheeled awsome.
Then your gonna want skid plates and either custom bumpers and or a winch. Then maybe some lockers but you should be able to get by without them.
Or you can do a solid axle swap which is alot more expensive and labor intensive. But if you want to do some extreme wheeling this is the best route.
Best advice I can give about wheeling is DO NOT GO ALONE.
post #8 of 11 (permalink) Old 01-08-2010, 10:13 AM Thread Starter
ok thanks
risk is offline
post #9 of 11 (permalink) Old 01-08-2010, 03:41 PM
when you say off road truck do you mean strickly trail truck,daily driver with some trail busting,rock crawling,mud racing?there are different ways to build for each.
post #10 of 11 (permalink) Old 01-11-2010, 10:24 AM Thread Starter
it would be a daily driving with some offroad
risk is offline
Would like some ideas Andertr F-150 1997 to 2003 /04 Heritage Forum 11 11-27-2009 06:26 PM
'06 Ranger Modification questions 99danger_ranger Ranger Forum 5 10-14-2009 12:45 AM
Some Ideas Justin1635 F-150 2004 to 2008 Forum 13 10-30-2008 06:04 PM
Want Some Ideas BapeStaarr Programmers and Tunes 9 10-21-2008 09:27 AM
