Day Time running lights - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 12-17-2009, 06:50 PM Thread Starter
hey guys i bet a couple of you have these takin off ur truck? i was just wondering what fuse it is/what else does it turn off...
2009 Ford Ranger Sport
31x10.5x15 Terra Trac's
Cobra CB Radio w/ BT
Waborita92 is offline
post #2 of 6 (permalink) Old 12-17-2009, 07:41 PM
i never had them on my 1999 could turn lights right off at night liked it that way i got my truck without them wish i could help you out but i think if you could pull a fuse it should have it in your owners manual on what one was your lights but i dont know if it would just be conected straight to all your lights
lonerangerxlt is offline
post #3 of 6 (permalink) Old 12-17-2009, 09:20 PM
I could be wrong, but I believe it's more than just a fuse. The fuse should provide power to the entire light (DRL and low and high beams). You might have better luck looking at the light switch itself. It works like a relay, so finding out which portion is responsible for what should give you what you need to know. You might want to look into a wiring diagram.
Slim is offline
post #4 of 6 (permalink) Old 12-17-2009, 10:01 PM
Chris.S.'s Avatar
There's a mod around somewhere to disable the drl. I had it a while ago but can't find it now.
It involves switching wires inside the cab in the fuse panel type thing.
Not much help I know, the point I wanted to make was that it can be done but not just a matter of cutting a wire or something. There's a number of things that you have to do.
Just some dude from BC...
Chris.S. is offline
post #5 of 6 (permalink) Old 12-17-2009, 10:03 PM
Chris.S.'s Avatar
This thread talks about it a bit:
http://www.fordtough.ca/forums/showt...hlight=disable
Chris.S. is offline
post #6 of 6 (permalink) Old 01-02-2010, 06:33 AM Thread Starter
thanks but i dont wanna **** around with the wiring right now lol its not old enough to **** something up yet, i was just hoping there was a single fuse to take out
What Head Lights Bulbs are you running? fordtough.ca Lighting 25 07-20-2012 01:11 AM
What Programmers are you running?? mechanix61 Super Duty Forum 15 12-30-2009 01:48 PM
What Exhaust are you running ........ fordtough.ca Intake, Exhaust 12 02-27-2009 11:28 AM
What exhaust is everyone running? ScottyV F-150 2004 to 2008 Forum 43 01-26-2009 12:55 AM
