NEED HELP: Time for New Wires - Need Some Input - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 03-08-2010, 08:49 PM Thread Starter
Question Time for New Wires - Need Some Input
1988 Ford Ranger XLT 2.9L - 5 Speed
Replaced spark plugs in fall - time to replace wires
Q? What wires do you suggest - Dealer or After Market [Bosch]
Q? What is the firing order for 2.9L
[DOES SOMEONE HAVE A PICTORIAL/DIAGRAM]
Q? Should I replace distributor & rotor also .. or just inspect visually
Also ... unrelated .... what's the BEST way to find air leaks from rubber lines
.... soap & water and spray and look for bubbles
Thanks for all input/suggestions
glassman
glassman08 is offline
post #2 of 3 (permalink) Old 03-09-2010, 04:49 AM
My 2 cents --
Any inexpensive aftermarket wires will be better than the 22 year old wires you have now. Don't know about firing order -- just replace one sparkplug wire at a time. Label the new ones. Use dielectric grease.
Why do you want to replace the distributor? Distributors are expensive. Is it having a problem? Usually you just replace the cap and the rotor if they are badly pitted and worn.
Re: leaks on hoses. I assume you are talking about vacuum lines. Soap and water won't show any bubbles, because it's a vacuum in the hose, not a pressure.
Given the age of your truck, the hoses are probably getting hard and brittle. It's much faster and easier just to replace all of them, rather than trying to chase down phantom vacuum leaks. I did it with my old '87 Nissan truck and it doesn't take very long, maybe an hour or two. Just go to an auto parts place and get as much bulk vacuum hose as you think you need to do the job, and replace one hose at a time. I think I did my entire engine with about 15' worth. It comes in several different diameters, so pull out a sample to show the parts guy. The main thing is to get a nice snug fit on the vacuum fittings.
If you do it that way, you won't have to worry about any vacuum leaks for another 20 years.
post #3 of 3 (permalink) Old 03-09-2010, 11:19 PM Thread Starter
Exclamation Thanks for the input ... Things got worse
Well good times can change quickly
Started up Ranger this morning ... sounded abit rough ... let it idle abit longer than usual - about 1 hour by the time I decided to take to garage.
Sounded like electrical [wiring] issue ... tried old fashion tips ... poured water on coil ... nothing - kept running. Shut truck off ... poured on water ... fired right up. hmmmmmm
With truck running poured on distributor ... abit of sputter ..but kept running
Drove up to garage ... mechanic met me outside ... truck didn't even make it into garage.
He checked all park plug wires
He checked [pulled] and cleaned rotor & checked cap
Brought out his 'doctor listener' .... engine problems - bottom end - sounds like a bearing I'm told .... NIICE
So to begin ... what now .. REBUILD or BUY another 2.9L
I'm told it's easier to change from underneath [rebuild] - IDEAS??
I know I'm feeling despair ... too much other invested in truck to scrap ... good times - solid original body
MANY NEW PARTS
Wheel Bearings & Seals
Brakes & Parking Brake Cable & Sensor
CAT converter and exhaust pipe
Alternator & Starter
Plugs, Oil Changes & misc
Heater Core & Hoses
Certified & Etested in Dec 2009
So ... anyone have PICTORIAL/VIDEO/EDITORIAL on how to change everything from underneath???
Show me what ya got!
Thanks :icon_cheers:
glassman
NEED HELP: Auxiliary Input keeick Ranger Forum 4 02-08-2010 11:47 AM
Need some input 98nascartruck Ontario 41 12-08-2009 02:55 PM
DynoLock correct wires 2010 HD jmeo F-150 2009 to 2014 Forum 2 11-02-2009 10:06 PM
plugs/wires noname42 F-150 Pre-1997 Forum 6 03-23-2008 04:00 PM
