Slip yoke play - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 03-17-2010, 05:25 PM Thread Starter
Slip yoke play
I found some play (up and down) in my drive shaft (slip yoke) and wondering if this could be to much. Seem quite too much to me. I do not know what the spec is for this but to my knowledge I should not have this kind of play.
2009 ranger 13000 KM
No load on my transmission I put the truck in neutral then hand brake then in park.
I made a short video at this link.
http://www.youtube.com/watch?v=rpPrsCL2DDY
maurice727 is offline
post #2 of 5 (permalink) Old 03-18-2010, 12:04 AM
Did you have the axle jacked up at the time or frame?
post #3 of 5 (permalink) Old 03-18-2010, 12:57 AM
a slight amount of play is normal(as long as the seal isn't leaking)as the yoke has to be able to slide freely in the tailshaft.
post #4 of 5 (permalink) Old 03-18-2010, 07:54 AM
I was just thinking about the spot where the seal seems to normally sit. If the truck were resting in its normal position, most of the play, what little there is, would disappear.
post #5 of 5 (permalink) Old 03-18-2010, 01:11 PM Thread Starter
My truck was on the ground on strait pavement.
got to play a little Northern Supercrew Truck/SUV Talk 11 03-18-2010 09:18 PM
CAR/TRUCK SHOW PICTURES: Slip on Tow Mirrors rgoulet58 F-150 2009 to 2014 Forum 1 03-16-2010 11:42 PM
Limited Slip Matty Ranger Forum 14 12-03-2008 02:48 AM
