NEED HELP: oh no! I done broke it! - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 04-14-2010, 10:06 PM Thread Starter
So im trying to put a new timing belt on my truck. FINALLY get the crank bolt out, then i pull on the pulley and SNAP, the cast iron part of the pulley cracks, and the pulley comes off. So now i need to buy a new one but im not sure if its one whole piece, or if it comes apart, looks like the start sprocket might pull off??
Does anybody know if i need to buy a new pulley with a new starter sprocket? or do they come apart?
Also, was this my harmonic balancer?
Is there anywhere i can get performance (or regular) replacement parts for this ?
camkos is offline
post #2 of 4 (permalink) Old 04-15-2010, 06:52 AM
Maritime Storm's Avatar
You should be able to get an aftermarket Harmonic Balancer through Dorman. Make a few calls. Expect $100 +/-
Maritime Storm is offline
post #3 of 4 (permalink) Old 04-15-2010, 03:38 PM
the balancer/pulley is one piece,and acording to service manuels doesn't have to be removed to replace belt,just remove the outer cover.
post #4 of 4 (permalink) Old 04-15-2010, 11:14 PM Thread Starter
thanks for the input, would have been nice to know that yesterday. i found a used one for $60 from the wreckers. probly best it broke, it was showing signs of wear from commuting on gravel roads.
camkos is offline
broke in the new tires vid/pics NVR2LO Off Road 4 04-19-2009 02:34 AM
2006 5.4 Dealer broke spark plug on last (warranty) visit will1563 Gas Engines 15 12-24-2008 08:33 AM
New Guy:broke down ford! corpral diaz New Members Introductions 15 10-30-2008 04:49 PM
WIFES WATER BROKE... HEAVY METAL British Columbia 16 11-24-2007 10:19 AM
