uh oh.. engine knock? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 05-01-2010, 03:31 PM Thread Starter
I recently replaced my timing belt and now after i stop at a red light and the engine returns to idle there is a knock that seems consistant with the rpm. A little throttle and the sound goes away. I havn't been able to jump out and find the sound because it doesn't happen every time. It was also doing this prior to the old timing belt snapping; not sure if they're even related. Any thoughts fellas???
95 2.3 5spd rwd
camkos is offline
post #2 of 3 (permalink) Old 05-02-2010, 10:34 AM
Maritime Storm's Avatar
Check the tension on the timing belt, the "knock" may be the belt slapping against the timing cover. If it's tight, use a mechaninc stethoscope(sp?) to locate the source of the knock.
Maritime Storm is offline
post #3 of 3 (permalink) Old 05-05-2010, 11:40 AM Thread Starter
The tension seems good ( about 3/8sth of an inch deflection). I can hear the sound through the plastic cover and through the brand new belt tensioner. It shouldnt be the tensioner since its new though, unless i have too much belt tension maybe?
camkos is offline
7.3 knock Black Ice Power Strokes All 1 04-01-2010 03:14 PM
Knock Sensor kidd F-150 Pre-1997 Forum 1 02-24-2010 03:35 PM
Engine swap? bluegoose Diesel Trucks 5 04-23-2009 03:44 PM
Not a knock on the forum...but Powerstroke2000 FordTough.ca Site Help? 5 09-05-2008 01:40 PM
Ranger Engine? fordtough.ca Ranger Forum 13 03-16-2008 08:40 PM
