NEED HELP: Help! - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 06-22-2010, 08:42 PM Thread Starter
Denis254's Avatar
Send a message via MSN to Denis254
Help!
I recently bought led replacement blalbs for my exterior lights, right after that my flasher was making wierd noices when i try to use it.. i got a new one and same problem.. any clues? i was reading on google and it said some newer vehicle need a led converter of some sort??
2008 Ford Ranger FX4 4.0
Denis254 is offline
post #2 of 7 (permalink) Old 06-22-2010, 11:07 PM
The voltage draw of the LEDs isnt enough so you need resistors so trick the truck into thinking its using the right amount.
2009 GO Ranger
Snepy is offline
post #3 of 7 (permalink) Old 06-23-2010, 02:54 AM
Replace your turn-signal fluid!
I think you can get replacement electronic turn-signal flasher modules that work with LEDs. Your new LEDs bulbs don't draw enough current to properly activate the old-school thermal contact type of module.
Installing resistors in parallel with the lights will work, but you'd have to experiment with the resistance value, and they'd be high wattage resistors (20-50 watts), which aren't that cheap, and they're bulky.
post #4 of 7 (permalink) Old 06-23-2010, 08:40 AM
An EP27 replacement flasher should fix you up.
http://www.partsource.ca/parts/automotive-parts.asp
post #5 of 7 (permalink) Old 06-23-2010, 12:00 PM
Yoy can get flashers, load resistors, and bulbs of all kinds here http://www.superbrightleds.com/cgi-b...rake-turn.html
post #6 of 7 (permalink) Old 06-23-2010, 01:33 PM
I guess I kinda don't get the idea of using load resistors. Isn't the idea behind using LEDs because they use less power? Adding resistors in parallel with the LEDs would defeat the purpose. At that point, you might as well just stick with incandescent bulbs, for a fraction of the cost and hassle.
post #7 of 7 (permalink) Old 06-23-2010, 08:14 PM Thread Starter
Denis254's Avatar
i order myself a electronic led flasher from that website "super bright leds".. thx for ur help every1! now gotta wait for it and hopefully that fixes the problem.. didnt even know they make led flashers..
Denis254 is offline
