Sticky Brakes - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 07-13-2010, 08:36 PM Thread Starter
Sticky Brakes
Hey guys, I'm having some brake issues with my '06 Ranger Sport 2wd.
The passenger front brake seems to be staying on from time to time. I replaced the pads a little less than a year ago. Early this spring I noticed that there was smoke coming that tire and the brakes were really hot.
From time to time I can smell the pads roasting from the passenger front. There is a serious amount of brake dust covering my wheel too.
I noticed when I changed my pads that they are worn unevenly. The inner pad was worn much more that the outer pad was on both front wheels.
Any tips or advice to help with my situation?
99danger_ranger is offline
post #2 of 5 (permalink) Old 07-14-2010, 03:01 AM
possibly a caliper problem i'd check there first. Its a fairly easy swap out
post #3 of 5 (permalink) Old 07-15-2010, 08:24 AM
Maritime Storm's Avatar
So what did we find, stuck caliper or brake hose?
Maritime Storm is offline
post #4 of 5 (permalink) Old 07-15-2010, 10:33 AM
It might be that you need to keep the slides for the pads clean and lubricated with the proper brake lube.My Super Duty needs this maintenance about every 6 months to keep the pads from hanging up.
post #5 of 5 (permalink) Old 07-24-2010, 10:56 AM Thread Starter
So as it turns out, the lower pin on the passenger side of the caliper was seized. Had to "persuade" it to get moving again and gave all pins on both driver and passenger side some lube.
Who needs brakes? tohi2care F-150 2004 to 2008 Forum 0 07-15-2009 01:23 AM
brakes fullyford F-150 1997 to 2003 /04 Heritage Forum 8 04-11-2009 05:18 PM
5.4 Broken Plug How to Video & TSB Sticky tohi2care Sticky Tech/How to Section 2 01-27-2008 01:31 AM
