How many of us suffer from transmission buzz? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 10-07-2010, 07:36 AM Thread Starter
Maritime Storm's Avatar
How many of you have and '09, '10, or '11 Ranger Sport, with a 4.0L/5Spd/3.55:1 set-up in 2WD and have a buzz through your shifter in 4th gear? I currently know of 2 trucks with this issue and that Ford is trying to find a fix for it. My local dealer has tried replacing the transmission fluid and shifter bushings to no avail.
Maritime Storm is offline
post #2 of 3 (permalink) Old 10-08-2010, 03:32 PM
does the noise only happen in 4th?,does it change in freq when move shifter further into gate?
post #3 of 3 (permalink) Old 10-09-2010, 06:53 AM Thread Starter
It's makes the noise on in 4th, putting ones hand on the shifter stops it. In the case of my truck it's intermittent, seems worse when it's hot out. The other truck Taylor Ford is working on apparently does it anytime it's in 4th. They tell me that the noise is "Torsional Vibration", the 4.0L engine vibrates under load through that particular gear ratio that causes the noise. Accordig to Ford it's unique to this particualr gearing. I was curious how common it was.
Transmission buzz at 2500 RMP wildcatt F-150 1997 to 2003 /04 Heritage Forum 12 10-15-2010 03:54 PM
NEED HELP: Transmission Bruicer Driveline and Transmission 1 08-19-2010 04:03 PM
What Transmission do you have? fordtough.ca Driveline and Transmission 34 04-04-2010 11:00 AM
Transmission issue... herbz Driveline and Transmission 6 03-22-2010 12:31 PM
What Transmission? Disposable-Hero F-150 Pre-1997 Forum 5 01-23-2008 12:26 AM
