Looking for a grill. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 12-13-2010, 03:28 PM Thread Starter
I've got a 2010 Ranger. Almost new I took a stone chip in the windshield. Since then I've heard a couple of others ping off.
My concern is that radiator hanging out there with very little for protection. Its only a matter of time.
I'm looking for an after market grill set that will protect the rad and look good. The more stone protection the better.
What say you?
Cheers!
Spring is offline
post #2 of 8 (permalink) Old 12-13-2010, 03:47 PM
My Father-in-law had a Ranger and had same issue. So I have a look then pull grill out and "Devcon" some plastic blocks on the back side and then mounted some stainless steel mesh, using the blocks for screw mounts. Turned out awesome for winter and summer.
post #3 of 8 (permalink) Old 12-14-2010, 09:42 AM Thread Starter
Never thought of that. Great idea!
If I can't find an after market one, I will no doubt go that route.
Thanks.
Spring is offline
post #4 of 8 (permalink) Old 12-14-2010, 10:03 AM
Check out some of the other Ranger-oriented forums, too. This kind of mod is fairly common for lots of different types of vehicles.
My rad was getting dinged-up, too. I salvaged some expanded steel mesh from an industrial engine air filter which didn't look too bad. I just cut it to size to fit behind my factory grille openings. It's held in place with cable ties attached to cable-tie mounting tabs that have 2-sided foam tape. Hasn't come loose or rusted over the past couple of years. I think the steel I used is zinc plated. It looks kind of stock.
For the lower opening, mine is protected by my license plate, which got relocated when I made a light bar for the front bumper. But you could put some mesh in there, too, if you want.
Judging from the number and size of paint chips on my valence, I'm sure the mesh has saved a lot of damage to the AC condenser/rad.
post #5 of 8 (permalink) Old 12-21-2010, 01:56 PM
Never even though of this.. I was more sad about all the chips in the top of my bumper and leading edge of my good. Some are pretttty big.
2009 GO Ranger
Snepy is offline
post #6 of 8 (permalink) Old 02-14-2011, 08:32 PM
Z1Krob's Avatar
Use window screen material. Just ziptie it in behind. It is invisible, cheap, easy to install and lasts for years. I used it on a Ram I used to have and it worked great. Was still in the truck when I sold it 6 years later.
2004 Ranger Edge
Z1Krob is offline
post #7 of 8 (permalink) Old 02-14-2011, 11:29 PM
Thanks for the info an keeps it stock looking also an cheap an easy to do as well
post #8 of 8 (permalink) Old 02-19-2011, 01:25 PM Thread Starter
Z1Krob.
I'll start with that while I continue to look for something that is both functional and stylish. Good idea. thanks!
Spring is offline
New grill is on! Newfordude Exterior 9 06-18-2010 05:30 PM
New grill ordered Newfordude Exterior 0 09-19-2009 05:49 PM
Grill Question... AB F250 Super Duty Forum 6 07-06-2009 10:12 PM
Saleen grill gewiens F-150 2004 to 2008 Forum 30 11-24-2008 06:54 PM
New Grill zip Super Duty Forum 15 11-01-2008 03:05 AM
