Gearing - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 43 (permalink) Old 09-19-2008, 10:22 PM Thread Starter
Justin1635's Avatar
Gearing
2008 60th aniversary f150
it has an 8 inch lift, dont know what manf.
and 37 inch tires. The spec sheet says it's running 3.73's, should i bring this up before i get the truck?
or is it ok running that?
Justin1635 is offline
post #2 of 43 (permalink) Old 09-19-2008, 10:26 PM
A programmer would help but I think a set of 4.56's or 4.88's would really wake that puppy up and get it moving and most likely be easier on fuel as well
post #3 of 43 (permalink) Old 09-19-2008, 10:27 PM Thread Starter
Justin1635's Avatar
i was talking more in terms of physical stress on the drive line and gas milage, although a tuner would be great i agree.
post #4 of 43 (permalink) Old 09-19-2008, 10:29 PM
Change it to 4.10 min for the price you are getting it
Truck will be sluggish with 3.73 and 37's
BTW
Did you take any pics?
post #5 of 43 (permalink) Old 09-19-2008, 10:36 PM
IMO 4.10 wouldn't be worth the money you'd get a better bang for the buck with the tuner, I run 4.56 gears on a 35.5 tire it works out the same as running 4.10 on stock 31.5 tire's if I was to run a 4.10 it would be the same as the stock 3.55 ratio that came with my truck not enough to get it moving on 35.5 tire's IMO I would put minimum 4.56 in there it will preform better and be better on fuel as well
post #6 of 43 (permalink) Old 09-19-2008, 10:36 PM Thread Starter
Justin1635's Avatar
BTW
Not yet, i'll be going back on monday to hopefully sign all the papers. maybe even tomorrow if i get time at work
post #7 of 43 (permalink) Old 09-19-2008, 11:03 PM
Have to agree with Dave 4.10 min and 4.56 ideal
It will be hard to get the truck going with 37's
post #8 of 43 (permalink) Old 09-19-2008, 11:23 PM
IF this hasn't confused anyone enough if you were to use a 4.56 gear on a 35" tall tire it would be like ruining a 4.10 gear on stock 31.5" tires, so a 37" tall tire with 4.56 would be around a 4.00 - 4.10 ratio If you like gear you may want to consider a 4.88 ratio
and yes back to your othe question ...with the right gears would be easier on the drivetrain
post #9 of 43 (permalink) Old 09-19-2008, 11:25 PM
post #10 of 43 (permalink) Old 09-20-2008, 02:54 PM Thread Starter
Justin1635's Avatar
you guys have succeeded in confusing me lol, so i go in there and he agrees to change the gears. What should i be running for best getupandgo/gas mileage.
Help regarding gearing jolliffem Ranger Forum 11 03-23-2008 06:15 PM
