lack of heat - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 03-28-2011, 11:38 AM Thread Starter
lack of heat
so i was driving home last night and realized i had no heat. i had my auto climate control on manual at 32 deg and it was only pumping out luke warm air.. once in a while it would pump out really hot, then luke warm again.. it did this for a bit.. now it just seems luke warm...
i noticed last summer my A/C wasnt cold cold but had the gauges put on and shes toped off of refrigrant....
are these some how connected? ive been doing research... could this be the blend door??
thanks
mike112 is offline
post #2 of 6 (permalink) Old 03-28-2011, 12:34 PM
sounds like it.
post #3 of 6 (permalink) Old 03-28-2011, 02:02 PM Thread Starter
i was just playing with my truck and noticed my A/C doesnt come on.. is it beacuse i have the auto climate control and its cold outside? or is this part of my problem now??
if i press the settings between defrost and floor and vent, the air movement does go to the proper place.. is it still the blend door?
mike112 is offline
post #4 of 6 (permalink) Old 03-28-2011, 05:10 PM
I think the dampers that control which vents the air comes out are different from the blend damper.
From what I've seen, replacing the blend door is a hell-job.
Check these sites for more info:
http://www.conceptualedge.com/blend-door/
http://www.heatertreater.net/
post #5 of 6 (permalink) Old 03-28-2011, 05:40 PM
prairiethunder's Avatar
I agree with b4000, replacing the blend-door looks pretty rough. Good luck
prairiethunder
2007 F-150 FX4
2007 F-150 King Ranch
1989 F-150 XLT
1949 F-1
prairiethunder is offline
post #6 of 6 (permalink) Old 03-29-2011, 12:57 AM Thread Starter
but the thing is, when its at 32 degrees, as i turn the tempeature down, it does get cooler.. its not like it stays at one paticular temperature.. thats whats throwing me off...
mike112 is offline
heat/ac problems trailing along Super Duty Forum 10 05-22-2013 02:24 AM
no heat in my 1998 explorer fordexploder05 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 1 10-18-2010 03:35 PM
No heat Fordwheeler Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 9 09-21-2010 10:02 AM
lack of power clawj Gas Engines 22 12-02-2009 11:35 AM
