NEED HELP: Cylinder #5 missfire - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 04-25-2011, 11:25 PM Thread Starter
Dadbro's Avatar
Hello there, I have a 06 5.4 L F-150. 180,000 km. I have put this truck through its paces and now it is putting me through some. I am getting a cyl #5 missfire code. I have put a new coil plus a new plug in the hole, and still getting the code showing up with the telltale hesitation. It only happens when the truck is under load, like acceleration, climbing a hill, when I back off the peddle it corrects itself.
Dadbro is offline
post #2 of 6 (permalink) Old 04-25-2011, 11:36 PM
prairiethunder's Avatar
That sounds like an interesting problem. Have you checked the wires?
prairiethunder
2007 F-150 FX4
2007 F-150 King Ranch
1989 F-150 XLT
1949 F-1
prairiethunder is offline
post #3 of 6 (permalink) Old 04-25-2011, 11:45 PM
maybe something here to help you.
http://www.obd-codes.com/p0305
not sure what the exact code was you came up tho.
post #4 of 6 (permalink) Old 04-26-2011, 03:29 AM Thread Starter
Dadbro's Avatar
I will check the wiring to the coil itself. plus do a compression test to eliminate the burnt exhaust valve or low compression. I did change out the #2 bank 2 oxygen sensor and that eliminated that code. I have my doubts that the catalytic converters are in good shape. I suspect they are plugged, so I best do a pressure differential test on those as well. I dont see how the plugged cat would affect just one cyl. though. Thanks for the help guys.
Dadbro is offline
post #5 of 6 (permalink) Old 04-26-2011, 11:46 AM
Did you clear the codes after you fixed the bad coil and changed the plug?
post #6 of 6 (permalink) Old 04-26-2011, 07:24 PM Thread Starter
Dadbro's Avatar
Yes, I cleared the codes but still after driving a few km's and trying to put a load on the engine it came right back. I am going to perform a compression test when I get back to work as well on that hole.
Dadbro is offline
NEED HELP: Slave Cylinder Slave to Cylinder F-150 Pre-1997 Forum 3 12-09-2009 01:23 PM
4.6 Cylinder head Fordwheeler Gas Engines 0 11-06-2009 09:24 PM
Master Cylinder? truckguy94 F-150 Pre-1997 Forum 8 05-20-2009 11:23 AM
NEED HELP: dead cylinder after replacing headgasket Jensen Gas Engines 5 05-12-2009 04:58 PM
F150 4.9 cylinder 2 missfire. please help!! gdowle Gas Engines 13 09-18-2008 11:10 PM
