Aftermarket custom rims - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 05-17-2011, 07:24 PM Thread Starter
I have a set of RTX 17" alloy rims on my 2005 F150.
The rims came with a Shank style lug nut to fit the M14 thread and 2.0 pitch on the rotors and hubs.
A few of the Nuts are worn, stripped and I need to replace them, problem is try to find a shank style nut to fit 14 x 2.0.
The original nuts were closed end but they were cut off to fit the stud length. I am having a hard time trying to source out the correct size.
There are lots of 14 x 1.5 nuts available but are the wrong size.
I need a Shank that is .68 wide x .55 long and a full length closed end to cover the exposed studs at least 2.0" long.
Does anyone out there have a solution?
Looking for some feedback
Thanks.
FordF154 is offline
post #2 of 3 (permalink) Old 05-17-2011, 10:10 PM
Have you tried Performance Unlimited in London ?
post #3 of 3 (permalink) Old 05-21-2011, 04:39 AM
Orangetang's Avatar
The set I just used on my truck sounds like what you need. I'm in the other boat, needing shorter nuts, since I can't fit my centre caps on, having such a long nut. I'll dig up the box they came in tomorrow, and posts some pics of what they look like if you want.
Orangetang is offline
aftermarket gauges Waborita92 Ranger Forum 10 12-20-2009 03:50 PM
Aftermarket Grille cnelson09 F-150 2004 to 2008 Forum 1 10-29-2009 03:00 PM
aftermarket step gbfitz F-150 2004 to 2008 Forum 4 09-23-2009 03:30 PM
aftermarket LayinHp Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 1 03-08-2008 05:35 PM
