NEED HELP: Misfire? Sounds like Exhaust leak.... - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 06-15-2011, 11:47 AM Thread Starter
Changed all coils and plugs (Motorcraft platinum) on my '04 5.4L 3v but the same issue is still there since I bought it almost a year ago.
When I floor it (or almost floor it) from a dead stop or going very slow I can hear a puffing sound. I pretty much can't hear it unless the windows are down and it only happens in first gear - seems to be between 2k and 3k rpm. It always makes the sound once, twice or three times all at once. I do have a hole in my muffler but my manifolds are not leaking.
I was wondering if it was the hole in my muffler that's causing the issue due to a lack of backpressure but I can't help but think it's something ignition related. It actually went away at one point in time after changing the plugs but only for a couple of drives and then it's back.
All of my ignition coil connectors seem to be connected properly. I had it in to the dealership a couple times about it but they can't seem to figure it out.
would it help if I capture the audio? I'm not sure if I can post that here....
any advice is appreciated
SCrew Lariat is offline
post #2 of 5 (permalink) Old 06-15-2011, 07:21 PM Thread Starter
I was determined to get this resolved after work today so I decided to begin the painstaking task of swapping out each coil with an old one, test driving after each swap.
I swapped number five and took it for a test drive when I realized I couldn't get it to make that stupid noise. I allowed it to warm up until the engine temperature was about a third of the way to normal according to the gauge before testing it. I did the test (floor it from stopped or slow speed) a half dozen times or so when I thought I heard that sound. The temperature gauge read about two thirds of the way to normal. Once the engine was up to temperature; the sound got more obvious and would happen every time.
That's when I remembered reading about the cam phazers TSB and how the rattling noise they make happens when the engine is hot. I always said that I thought my truck sounds like a diesel when it's hot (even though the dealer always would say that was just the injectors).
So, I'm guessing that maybe because I have the '04, I probably have the outdated phazers and maybe if I replace them, both the diesel sound (phazers/chains), and the misfire (puff sound) will go away.
Any thoughts or suggestions about it anyone?
Thanks again.
post #3 of 5 (permalink) Old 03-08-2012, 11:54 AM Thread Starter
so I meant to update this thread back in Dec when I replaced my muffler.
I knew there was a hole in the damn thing but I was certain that it wouldn't be the cause of the issues I was having. WRONG!!
replaced it with a 14" (I think) Magnaflow and the truck has never had a problem since. It seems to work way better too!
should've done that when I bought it for $230 installed.
post #4 of 5 (permalink) Old 03-16-2012, 01:33 PM Thread Starter
I stand corrected. It sputtered today when under heavy acceleration (not WOT) just before it shifted to second gear.
Back to the drawing board.
post #5 of 5 (permalink) Old 05-30-2012, 03:26 PM
Big Daddy D.'s Avatar
Question... do you always purchase your fuel from the same location?
Still not getting any codes at all?
I have access to a top Ford Truck Tech, I'll get him to read your post threads on here regarding this issue.
Edit: the Ford Tech Guy that I know of is a member on here, under the name "JimmyK" , so either do a search for him or you'll find him over in the Ranger truck forum section.
Hope this helps you.
Press on regardless!
Big Daddy D. is offline
NEED HELP: Exhaust Leak-i think? blaster23 F-150 2004 to 2008 Forum 18 06-19-2011 01:38 PM
4.6l sounds like an exhaust leak Haley-Special F-150 1997 to 2003 /04 Heritage Forum 11 06-01-2010 10:19 AM
exhaust leak solution 78F150 F-150 Pre-1997 Forum 0 05-06-2010 01:09 PM
NEED HELP: timing? misfire issue? Hammermill97 F-150 2004 to 2008 Forum 6 09-25-2009 11:39 PM
Exhaust leak Fordwheeler F-150 1997 to 2003 /04 Heritage Forum 21 08-13-2009 07:45 PM
