looking for info - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 07-04-2011, 10:45 AM Thread Starter
bruteforce650's Avatar
looking for info
My wife and I are currently looking into buying a bigger trailer but little 4.6l comes with 2 different gear ratios and wheel base sizes. where do I find that info?
bruteforce650 is offline
post #2 of 15 (permalink) Old 07-04-2011, 11:22 AM
If you still have your window sticker it will tell you the gear ratio of your truck. If not you can decode the vin to figure it out. The dealer can tell you as well. How big of a trailer are you planning on pulling with that "little" 4.6l? I hope you have 3.73's in the rear-end.
post #3 of 15 (permalink) Old 07-04-2011, 12:14 PM
Wheel base will be 126, 133, 139, 145 or 163 inches - listed under "WB" on the bottom of the pillar inside the driver's side door
Gear ratio will be as follows - listed under "AXLE" on the same sticker:
19 = 3.55 non Limited Slip
25 = 4.10 non LS
26 = 3.73 non LS
27 = 3.31 non LS
B5 = 4.10 Limited Slip
B6 = 3.73 LS
H9 = 3.55 LS
SCrew Lariat is offline
post #4 of 15 (permalink) Old 07-04-2011, 12:45 PM Thread Starter
thanks guys
post #5 of 15 (permalink) Old 07-05-2011, 12:37 PM Thread Starter
I got 3.73 gears and looking to haul a trailer around 26 feet long.
post #6 of 15 (permalink) Old 07-05-2011, 03:35 PM
I'm not the best person to answer that question as 1. I don't tow and 2. I don't have a 4.6 with 3.73s but I'm going to give you my opinion anyway lol.
The 26' trailer will likely be a tall order for that truck. I think it's all about how much towing you'll be doing i.e. are you towing it to a spot for the summer and leaving it there until fall, or are you going to be putting on alot of miles. The framing of the trailer (aluminum or steel) will also play a large factor in the weight of the trailer which will make a big difference in how much work it'll be for the truck.
If you're just towing it once in awhile, I'd say you should be OK. However, like I said, I'm not the expert.
post #7 of 15 (permalink) Old 07-05-2011, 10:52 PM
I don't think you should have a problem towing that size of a trailer, if you notice your truck down shifting out of 6th gear alot just turn your tow/haul on and your truck will handle the trailer much better.
post #8 of 15 (permalink) Old 07-05-2011, 11:55 PM
http://www.f150forum.com/f38/5th-whe...m-doing-52823/
Lots of info in regards to proper towing.. as well covering alot of 5th wheel specific stuff
post #9 of 15 (permalink) Old 07-06-2011, 01:14 AM
What about weight? Thats really more important than length. Probably 3000-3500 dry weight is the most you'll want to go
post #10 of 15 (permalink) Old 07-06-2011, 10:10 AM Thread Starter
The trailer that we have in mind dry is about 4500lbs. We will be driving with it alot possibly we have tossed the idea of a seasonal spot. I don't have a tow/haul button on mine but I can shut the o/d off.
Need info on tuners Justin1635 Programmers and Tunes 2 09-23-2008 09:00 AM
Sub woofer info CanadianRanger Ranger Forum 6 08-20-2008 12:49 PM
Pacesetters, need info? Smokefan Wheels and Tires 3 11-08-2007 10:23 AM
Whitby meet info fordtough.ca Ontario 38 03-16-2007 08:36 PM
