Why Ford..Why - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 08-04-2011, 12:12 AM Thread Starter
Why Ford..Why
So i go to change my fuel filter again..2nd time in 70,000kms. The owner's manual calls for a 986B..so that's what i get. Guess what..the bitch don't fit. The pipes off each end of the filter are too small, the fuel lines are sloppy on the filter and leak like a seive..I look at the old filter and it's a 1083 Ford #. Bigger tubing and bigger inside diameter of the tubing..After screwing around taking the old one off ( traveling a gravel road sure don't help) i put the old one back on and no more leaks...Any one else run into this prob? I read somewhere that Ford changed filters around 06 and too check which color clip is on the tank side of the filter..mine is a red clip..I can't understand why the 1st filter change went smoothly. The filter was bought at Crappy Tire..at least their book got it right...Rant over
post #2 of 11 (permalink) Old 08-04-2011, 12:47 AM
They changed the fuel line size at the end of 05. My 06 has a late 05 build date and needs a fuel filter from an 05 not an 06. I found out the hard way ie. truck on ramps fuel filter removed and new filter didn't fit. I can't remember which year had bigger fuel lines, I think it was the 05
post #3 of 11 (permalink) Old 09-14-2011, 11:34 PM
same here. I had to bring in the original one and i think it was a filter for 07 or something like that.
simonw is offline
post #4 of 11 (permalink) Old 06-25-2014, 05:15 PM
Big Daddy D.'s Avatar
CTC... Crappy Tire... Come Take a Chance...
Press on regardless!
Big Daddy D. is offline
post #5 of 11 (permalink) Old 06-25-2014, 05:31 PM
Three years, three replys. Wow.
post #6 of 11 (permalink) Old 06-26-2014, 07:08 AM
Yup... super active website...
post #7 of 11 (permalink) Old 06-26-2014, 07:16 AM
It's all about participation, nicely done. Try some of the threads that haven't been dead for three years, there's plenty out there.
post #8 of 11 (permalink) Old 06-26-2014, 07:18 PM
I like Fords Too's Avatar
eah
sometimes ya learn more if you dig all the way down to the bottom of the box
I like Fords Too is offline
post #9 of 11 (permalink) Old 06-27-2014, 09:25 PM
Too bad most of the people at the bottom of the box are long gone or the issue in the thread is long forgotten.
post #10 of 11 (permalink) Old 04-19-2015, 09:16 AM
Hmm.. didn't check the date of the post at the time, was just trying to help... at the time.
