08 F150 DRL's - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 01-20-2012, 10:06 PM Thread Starter
08 F150 DRL's
Hey guys,
Do the DRL's on the F150's stay on all the time even when the park brake is on? I did a search online and it's my understanding that they dont shut off on the Fords?? In the morning when im warming up my truck im lighting the people accross the street bedrooms,or I cant run my truck when im listing to tunes in the parking lot at work. If there's no fix for it,how can I disable them without affecting anything else?
2008 Ford F150 STX 4.6L,4x4
qwikz74 is offline
post #2 of 13 (permalink) Old 01-20-2012, 10:45 PM
tell them to get better curtains. tinfoil works well.
not sure on your model. but the 97-03 just has a resistor that i unplugged. NO DRL at all.
post #3 of 13 (permalink) Old 01-20-2012, 11:26 PM
Older trucks you used to be able to put a switch in to shut them off. I believe it was wired positive to ground but can't quite remember. " Must be old age!' Check with a dealership mechanic.
post #4 of 13 (permalink) Old 01-21-2012, 10:39 AM
Helps with alien mind probes as well, but for 100% protection you need a hat.
Just for conversation's sake, the DRL's on the newer models stay off until you put the truck in gear.
post #5 of 13 (permalink) Old 02-19-2012, 02:57 PM
700summitguy's Avatar
On my 05, I found the resistor on the drivers side of the rad.It is on the grill side of the rad support under the rubber cover, by the headlight. Unplug it and it goes back to normal.
2005 King Ranch. 2007 Ranger Level 2. No act of kindness goes unpunished.
700summitguy is offline
post #6 of 13 (permalink) Old 02-19-2012, 03:59 PM
x2
You can't miss it. Driver side just below the headlight by the rad. Unplug it and no more DRL's.
post #7 of 13 (permalink) Old 02-22-2012, 04:53 PM Thread Starter
Is this the resistor?
qwikz74 is offline
post #8 of 13 (permalink) Old 02-23-2012, 03:14 AM
Yes it is.
post #9 of 13 (permalink) Old 02-23-2012, 07:27 AM
TRUKNUT's Avatar
If you look in your owners manuel there is a section that explains how to disable the DLR's
when your truck is in park . I had the same concerns because I leave so early in the am and
my lights were waking up my neighbour.
TRUKNUT is offline
post #10 of 13 (permalink) Old 02-23-2012, 11:49 AM
I did mine because I use my auto lights and I was having issues with my HID's on start-up, they draw a lot of power to get going and usually only 1 would end up coming on with the combination of the lights trying to come on and the engine needing power to turn over. You guys are just too nice if you disable them so you don't wake up your neighbors.
2010 F150 or 2011 F150 benyl F-150 2009 to 2014 Forum 29 09-18-2010 11:06 AM
