04 fX4 4wd shifting Problems - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 01-22-2012, 01:48 PM Thread Starter
Hi All, I turn my 04 FX4 know to 4 hi and the light comes on but it will not go into 4 hi. It is cold up here in Ontario. It was working about a month ago. Any ideas.
iohwyswn is offline
post #2 of 8 (permalink) Old 01-22-2012, 03:02 PM
smokeshow's Avatar
if it's electronically controlled I would guess there is a solenoid that is to engage the system. i bet the cold or a wire isn't doing it's job.
smokeshow is offline
post #3 of 8 (permalink) Old 01-22-2012, 03:50 PM Thread Starter
Thanks SMokeshow, any ideas where the solenoid is, i will check to see if there is power to it.
iohwyswn is offline
post #4 of 8 (permalink) Old 01-22-2012, 04:07 PM
No expert by any means, but that sounds as reasonable a place to start as any.
Welcome to fordtough.ca....great crew on here and lots of helpful advice to be found.
post #5 of 8 (permalink) Old 01-22-2012, 04:40 PM
smokeshow's Avatar
yeah i've never even owned a 4x4 but my train of thought is there.
I'm sure if you got under the truck and looked at the transfer case you'd see some wires or a wire going to it. I'd put a buck on a bet that the solenoid is right behind the wire. I'd follow the wire first and look for some breaks and then if all looks good see if there is a way to get to the solenoid and then just test it. if it's good then your back a square one... if it's not well then you know what to do lol.
post #6 of 8 (permalink) Old 01-22-2012, 04:43 PM
smokeshow's Avatar
http://www.google.ca/imgres?q=2004+f...t:429,r:11,s:0
That link will take you to what is a picture of the shifting mechanism...
http://www.google.ca/search?tbm=isch...1586l1.11l12l0
This link will take you to images of the transfer case in google... one is what you want to look for the other is where you will find it.
post #7 of 8 (permalink) Old 01-22-2012, 11:19 PM
http://www.f150online.com/forums/art...-pictures.html
I was having a similar problem. It too started out of the blue. I bought the new style solenoid with the hood from rock auto for about $15. It solved the problem. The link shows you where the solenoid is and what it looks like. It takes about 10 min to change. It was a 10mm wrench IIRC
post #8 of 8 (permalink) Old 01-24-2012, 11:33 AM
everything you need to know about IWE and more:
http://www.f150online.com/forums/art...then-some.html
SCrew Lariat is offline
4WD sound seadragon F-150 2009 to 2014 Forum 16 03-08-2011 04:51 PM
No 4wd Low dave151 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 7 03-02-2011 08:50 PM
4wd Issue herbz F-150 2004 to 2008 Forum 1 03-01-2011 03:45 PM
NEED HELP: 09 f150 shifting problems gapperf150 F-150 2009 to 2014 Forum 1 07-06-2010 04:08 PM
Shifting Bliss. canadian.bacon Ranger Forum 21 08-18-2009 10:06 PM
