Goodyear Wranglers Duratracks - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 14 (permalink) Old 07-04-2012, 12:51 AM Thread Starter
Cav
Cav's Avatar
Been thinking of picking up a set of these. Will they fit with no issues on my 07 XLT Supercrew. Looking at 275/70/R18's. Thanks!
Cav is offline
post #2 of 14 (permalink) Old 07-04-2012, 08:16 AM
dk9
i want those also but they do not fit my 09 screw fx4
275/55/r20
go to goodyear or crappy tire website, punch in the tire size or vehicle details.it will tell
the truck is now 84,000 km and i dont like the look of the pirelli scorpions, while the truck safetied when we got it in feb, i feel those tires have outlived their live.
dk9 is offline
post #3 of 14 (permalink) Old 07-04-2012, 07:08 PM
You can also use tirerack.com
Cav what size are your stock tires ? if your not changing the size to much you shouldn't have any problems
post #4 of 14 (permalink) Old 07-04-2012, 07:21 PM
I'm guessing his stock size is 275/65/18. A 275/70 will fit no problem.
post #5 of 14 (permalink) Old 07-04-2012, 09:22 PM Thread Starter
Cav
Cav's Avatar
^^ you got it, i have BFG Rugged Trails on there now, 275/65/18. Looking for something a little bigger. Like the look of the Wranglers and the BFG All terrains, but i think im leaning toward the Goodyears. Would it still be doable if i went 285?
Cav is offline
post #6 of 14 (permalink) Old 07-05-2012, 01:20 AM
I run 285/65R/18 All terrains on my 04 and I believe Herbz is running the same
post #7 of 14 (permalink) Old 07-05-2012, 09:54 AM
Here's how it breaks down:
275/70/18
Height: 33.15"
Width: 10.82"
285/65/18
Height: 32.6"
Width: 11.22"
Goodyear doesn't make the Duratrac in 285/65/18 but they do make it in 295/65/15 and based on the numbers they should fit as well. Maybe only minor rubbing depending on how much your suspension on your truck has settled.
295/65/18
Height: 33.1"
Width: 11.61"
post #8 of 14 (permalink) Old 07-05-2012, 10:14 PM
For reference
the stock tire is a 32.1" tall tire
33x12.5 x18 will probably be pushing it due to the width. If you were to step up the larger I'd recommend an aftermarket set of offset wheels.
post #9 of 14 (permalink) Old 07-05-2012, 10:33 PM
Here are some choices in the 285/65/18
http://www.tirerack.com/tires/TireSe...65&diameter=18
post #10 of 14 (permalink) Old 07-05-2012, 10:35 PM
http://www.tirerack.com/tires/tires....omCompare1=yes
goodyear duratrac? racert17 Wheels and Tires 2 08-03-2010 08:16 PM
Goodyear Tires?? Frosty Ranger Forum 12 02-15-2010 06:15 PM
Goodyear Eagle NASCAR #1 f150phule F-150 1997 to 2003 /04 Heritage Forum 6 01-21-2008 12:55 AM
